What kind of controller do you have?
Wade
hi everyone.problem is this .when i jogg it will go a little ways and stops and then you loose the function to the keys .The only way to get going is to reset and try it some more but then it does it all over.i have reinstalled several times same deal.anyone have any ideas?
Wade
What is it? the machine? Do the DROs stop?
Nick http://www.nixstuff.com
http://www.youtube.com/watch?v=jTu7wicVCmQ
Is anyone familiar with this "problem". :-)
When I press arrow key to move ( for example) in Y+ direction and at the same time press other arrow key to move to the X+ dir, the machine does not respond to X+ command , and continius to move only in Y+ dir. This started to happen recently, and since then I can not move gantry diagonaly !?.
To be more precise, I can run machine diagonaly , but only in the direction : Y+ / X-, and in other cases the machine goes only in the direction that the arrow key pressed first.
Z axis works fine.
Thank you in advance on the suggestions ...
I had a similar issue from new on a chinese machine (YongNuo USB breakout) but it went away when I switched to a UC400-ETH ethernet controller + a breakout board. I'd always assumed it was just the cruddy YongNuo breakout that was getting messed up, but now I'm interested to see if it was something else.
False alarm :-)
The keyboard was full of dust, and caused "problem"
