Deformed path/infill at higher speeds.
Results 1 to 2 of 2
Thread: Deformed path/infill at higher speeds.
    Activation process Ricc's Avatar
    Aug 2018
    Default Deformed path/infill at higher speeds.
    Hello everyone. I have a stepper motor milling machine. I have attached to it an extruder so that I can make 3d prints. I am only reporting this detail because the part I am showing you is a 3d print part. But the problem is almost certainly related to something wrong with the motors.
    I was printing a small parallelepiped to calibrate the print parameters for that relatively high speed, and it turns out that the filling movements of one face of the parallelepiped are incorrect, despite the fact that the gcode looks correct. I enclose two photos of the piece, in one I show better the brushed area(in red) and the direction of the brush strokes (black). As you can see only half of the cube is done correctly while in the other half(it seems to me always the initial half) the brush strokes are interrupted prematurely. It goes at speed 3600 mm/min, if I reduce example to 2000 the problem disappears. Any idea why this happens? In theory the machine at these speeds should succeed. And then if it can do the second half it is not clear why it cannot do the first half.
    Attached Thumbnails Attached Thumbnails Deformed path/infill at higher speeds.-stampa_deforme2-jpg   Deformed path/infill at higher speeds.-stampa_deforme1-jpg
    Attached Files Attached Files
    Aug 2018
    Default Re: Deformed path/infill at higher speeds.
    Ok I found what was wrong. I forgot about those options; I had constant velocity checked in general settings but the CV tolerance was way too high. I now have set it to 0,1mm and everything seems back to normal. Actually, the quality of 3d prints, from the first tests, seems to be increased a quite a bit even at high speeds as compared to my preceding prints that were run at lower speeds. Still I don't understand why the second half of the geometry was printed correctly whilst the first half no. But well, I am satisfied anyway.
