Need Help! 4th Axis working, but very jerky
Results 1 to 9 of 9
Thread: 4th Axis working, but very jerky
    Jun 2016
    Default 4th Axis working, but very jerky
    I've been reading and attempting everything I have found. My 4th axis is working surprisingly well, but its very jerky. I'm using fusion 360 with usb smoothstepper and have tried various smoothing settings, slower feed rates and it all yields the same results. Theres a video below with some sample code.
    I see lots of people with harmonic drive 4th axis and mach3 and they all seem so smooth. The pausing is adding a decent amount of machining time and leaving marks on my finish. Does anyone have any ideas what's causing the jerkiness/stuttering?
    Code:
    Z0.6334 A-6.574 F2836.3323Z0.6395 A-9.401 F2653.4703
    Z0.642 A-10.341 F7665.2579
    Z0.6468 A-12.217 F3861.3871
    Z0.6488 A-13.152 F7937.2541
    Z0.6507 A-14.087 F7996.3277
    Z0.6523 A-15.02 F8146.2995
    Z0.6538 A-15.953 F8273.91
    Z0.6551 A-16.884 F8360.7096
    Z0.657 A-18.745 F4297.0773
    Z0.6582 A-20.603 F4442.1249
    Z0.6585 A-21.531 F9124.6597
    Z0.6584 A-23.387 F4677.8014
    Z0.6582 A-24.315 F9147.9255
    Z0.657 A-26.171 F4444.8371
    Z0.655 A-28.029 F4297.6506
    Z0.6537 A-28.958 F8398.9712
    Z0.6522 A-29.888 F8277.2542
    Z0.6506 A-30.818 F8155.041
    Z0.6487 A-31.75 F8035.2122
    Z0.6467 A-32.682 F7924.6533
    Z0.6445 A-33.616 F7856.4056
    Z0.642 A-34.55 F7700.0207
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    Default Re: 4th Axis working, but very jerky
    Try this code:
    G00 A000 Z250
    G01 A180 F12
    Dec 2013
    Take a look at the feed speeds in the G code, they are all over the map. Every line has a different speed. The action in the video looks like it is following the G code commanded speed.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2018
    United Kingdom
    Quote Originally Posted by Jim Dawson View Post
    Looks like Jim is the winner!
    Wow. I wonder how that happened?.
    Need to figure out how to stop that happening, wouldn't fancy having to edit every line of code to delete the F rates!
    Must be something in Fusion. Different feedrates for smoothing, roughing, finishing, plunging, cornering etc must have been set.
    Jun 2016
    Quote Originally Posted by dazp1976 View Post
    I should have mentioned that fusion is using the inverse time mode for this moves.
    LiGHT-FiSH's Avatar
    Aug 2022
    Hi, I have the same problem with the rotary extension in fusion360. I set :cutting feed rate, lead in and lead out, ramp and plunge all to the same feed rate. When I generate the gcode every line has it's own different feed rate and gives a jerky cut. Its also quite a bit slower then what I had running before where I added the rotation numbers manually. Anyone have any suggestions?
    here are a few lines of the code:
    O0001(ROTARY1 2)
    G0 A-90.
    X0.4 Z19.798
    G1 X0.392 Z19.417 F1000.
    Z17.798
    X0.38 Z17.702
    X0.342 Z17.605
    X0.278 Z17.518
    X0.192 Z17.452
    X0.096 Z17.412
    X0. Z17.398
    G93 Z17.395 A88.833 F18.4136
    Z17.398 A267.749 F18.4053
    Y-1.998 A270.35 F1262.6583
    Y-1.993 Z17.395 A271.173 F3915.5086
    Y-1.986 Z17.398 A272.445 F2537.1061
    Y-1.98 Z17.395 A273.517 F3007.2727
    A273.526 F355836.3751
    Y-1.973 Z17.398 A274.771 F2591.9728
    Y-1.967 Z17.394 A275.906 F2839.2202
    A275.915 F356034.426
  7. #7
    Member awerby's Avatar
    Apr 2004
    You could edit the code, searching and replacing all those A axis speed commands. Or get DeskProto and write better A axis code.
  8. #8
    Member mactec54's Avatar
    Jan 2005
    We don't see the complete program if it has a G93 call, then each block has to have a feed rate
    Mactec54
  9. #9
    Jan 2005
    Quote Originally Posted by LiGHT-FiSH View Post
    O0001(ROTARY1 2)
    G0 A-90.
    X0.4 Z19.798
    Z17.798
    X0.38 Z17.702
    X0.342 Z17.605
    X0.278 Z17.518
    X0.192 Z17.452
    X0.096 Z17.412
    X0. Z17.398
    The G93 is the cause of this problem as when using a G93 this will require each line of code to have a feed rate
    This G code specifies that all F (federate) values are interpreted as strokes per minute. In other words, the time (in seconds) to complete the programmed motion using G93 is, 60 (seconds) divided by the F value.
    See if you can use a G94
    Feed Per Minute (G94)
    G94 G-code is a modal G-code. G94 instructs the control to interpret feed commands as
    Inches/minute or mm/minute for linear moves.
    degrees/minute for rotary moves.
    Inches/minute or mm/minute for a combination of linear and rotary moves.
    When a combination of linear and rotary moves is programmed, the rotary moves match the time it takes to make the linear moves.
    Mactec54
