M10/M11 macros in Mach3 seem to be a "work in progress", they have never been implemented completely. You should probably just add your own macros containing commands "ActivateSignal(OUTPUT6)" and "DeactivateSignal(OUTPUT6)".
I have added a laser module to my homemade CNC. for some reasons I was ending up using an output to control the laser (rather than using the spindle's PWM output).
My module is connected to output pin 14 on my board (novusum nvcm6v2.1). the output is defined as OUT6 in Mach3.
Setting coolant (M7) to out 6 works and controls the laser - so I know this whole setup is functioning.
HOWEVER,
If I'm trying to use M11P6 to turn the laser on (instead of coolant control), and M10P6 to switch if off - they does not work.no reaction.
at 1st I suspected the board but when I'm switching to the Diagnostics tab on Mach and I'm running these commands, I don't see the 'LED' of output 6 changing. further more - it does not work on any output whether I have something connected there or not.
(I also tried using M11 with movement, i.e. M11P6 G0 X100 since I rad that it is a command that waits (don't remember the precise name of it). the unit moves but it does not turn the laser on.
Questions:
1. Does M11/M10 needs some special settings to work?
2. When using these commands, do you see the Leds changing in the diagnostics tab?
thanks,
Gil
- Please Help! Issue that cannot be resolved. Stalling Z Axis Issue
- Incoming Power Issue, or Transistor Issue
- Newbie- Seems Z and A axis are not running...Motor issue or Step/Dir issue?
- sprutcam 9 tool library issue, waterline issue, was working fine
- Help with selector switch wiring issue (***actually a motor issue***)
And if you are using a 3rd party motion controller, it may not support M10/M11.
UCCNC 2017 Screenset
