It is a NO-NO calling a macro within a macro. It just does not work.
Hey everyone, I have a mach3 custom macro question.
I am trying to create a macro that I can call through gcode that will automatically load and start a new gcode file.
I my script works perfectly if I run it from the vbscript editor or if I create a button that runs it in mach3. But if I try to type the mcode into mdi it starts to load the gcode but it gets stuck on the "generating toolpath" window.
So if I type in M997, my custom macro, it doesn't work. But if I make it as a button it does load a gcode file and automatically starts my gcode?
This is what my code looks like
LoadFile "gcode.txt"
While IsLoading()
Wend
runfile()
And to give more details on what I am trying to do, because maybe there is another solution.
My machine is a 4x8 router that has automatic sheet loading and material push off for when finished. I am trying to set it up where I have a a custom post processor for when I want the machine to keep cutting the same file on multiple sheets.
My current method is, run the gcode cut file at the end of the file it runs a custom macro that turns off the vacuum table and clears the cut parts on to the conveyor belt. Then I need the machine to load and start a new gcode to sweep the table with the routers dust brush. (That's where my first problem is) after it is swept it will run my auto load macro that grabs a sheet and places it on the spoilboard. That part works fine, but then I need it to load another gcode file and start that cut.
Sorry if that's too much or not enough information ????
Thanks for the help,
Mike
Make no mistake between my personality and my attitude.
My personality is who I am. My attitude depends on who you are.
calling macro from G-code is correct. Your explanation is a bit messy. I still don't understand, where the problem is. If You are able to define customer macro, do as many macros as you need and call them one-by-one from Your G-code...
If you try to run a g-code file from within a g-code file, you'd be trying to run two files at the same time. Not going to work.
What you probably want to do is run the second file as a subroutine. I think you can call an external file as a sub, but it's been a long time and don't recall exactly.
UCCNC 2017 Screenset
