Mach3 jog speed
Results 1 to 3 of 3
Thread: Mach3 jog speed
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Mach3 jog speed
    I have a Mach3 mill with different motors on each axis. X and Y have the maximum speed of 5000mm/min, while Z can only do 1500mm/min.
    Problem is, the jog speed in Mach3 is set as a percentage of the maximum speed for each axis. If I set the desired speed for the X/Y, then my Z axis jogs too slow. If I set a reasonable speed for the Z axis, then the X/Y movement becomes too fast.
    Is there any way to adjust the jog speed for each axis independently?
    Dec 2009
    Default Re: Mach3 jog speed
    If you set the speed you want for the xy axis to say 50% then when you jog Z you should be able to press shift+Z jog key to jog at max on Z just a thought.
    Nov 2012
    Quote Originally Posted by squirrel_41 View Post
    Unfortunately, the keypad I use for jogging does not have a shift key. But thanks for the food for thought, maybe I can make a key macro or something.
Mach3 jog speed
Mach3 jog speed
Mach3 jog speed
