Need Help! CNC skips/transpose code during working [pctures included]
Results 1 to 3 of 3
Thread: CNC skips/transpose code during working [pctures included]
    Member christzerefos's Avatar
    Oct 2020
    Default CNC skips/transpose code during working [pctures included]
    Hello to all,
    I have a CNC 6040, operating with a Mach3 software. The problem I encounter is that during the run of the code the CNC makes one small freeze/stop and then it transposes the field of work several millimeters to one side. Then it continuous normally but transposed. I have also attached pictures to explain you.
    Any ideas??
    Thank you for your time.
    Attached Thumbnails Attached Thumbnails CNC skips/transpose code during working [pctures included]-correct-cut-jpg   CNC skips/transpose code during working [pctures included]-1-jpg   CNC skips/transpose code during working [pctures included]-3-jpg
    Member awerby's Avatar
    Apr 2004
    Default Re: CNC skips/transpose code during working [pctures included]
    This is called "lost steps". It happens when a move is commanded that a stepper is unable to execute. Identify the axis that is faulting, go into its settings under Motor Tuning, reduce the acceleration by about half, "save axis" then try the program again and see if it got better. Other causes can include mechanical issues, too high a speed commanded, not enough voltage, etc. but reducing acceleration often works.
    Oct 2020
    Quote Originally Posted by awerby View Post
    Thank You for your response.
