Need help with setting parameters on Output #1
Results 1 to 6 of 6
Thread: Need help with setting parameters on Output #1
    Nov 2010
    Asia
    Default Need help with setting parameters on Output #1
    I have a MKS4-V board made by a chinese company called Cheng du Xing Cheng Technology Co. LTD. I have connected the 6 wires for controlling the spindle. It can control the spindle using the VFD panel control including the rpm. But I cannot control the spindle using Mach3. The spindle has no response when I click Spindle Cw F5 button on Mach 3 BUT the VFD fan turns on.
    VFD model is MK100-2S1.5G-DK it's a 1.5kw made by a company called Nangtong Hui Automation Equipment Technology Co. Ltd.
    Laptop is a 32 bit Windows 7
    It could be some numbers in Configuration - ports and pins- output signals -- Output #1 (port# 1, pin # 14) incorrect.
    Any help would be appreciated.
    Regards
    Lasercut
    Attached Thumbnails Attached Thumbnails Need help with setting parameters on Output #1-15936780601101865053167-jpg   Need help with setting parameters on Output #1-1593677703805-825873404-jpg   Need help with setting parameters on Output #1-photogrid_1593677618736-jpg
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Need help with setting parameters on Output #1
    ...VFD settings maybe need changed. Found a manual via linuxcnc user may help you.
    https://onedrive.live.com/?authkey=%...%21114&o=OneUp
    DJ
    Nov 2010
    Asia
    Quote Originally Posted by machinehop5 View Post
    DJ
    I have this exact manual and already setup the parameters on the VFD as well but spindle is still not turning via Mach3. What numbers in the Output signal should I key in for port and pins? Anyone?
    Nov 2010
    Asia
    Ok it's solved. Thanks
    Aug 2009
    Quote Originally Posted by lazercut View Post
    ...great. What was the problem?
    Nov 2010
    Asia
    The problem was I have not key in the Spindle speed for the motor.
