Need Help! Computer crash-new computer and now Mach 3 not working
Results 1 to 6 of 6
Thread: Computer crash-new computer and now Mach 3 not working
    Jan 2005
    Default Computer crash-new computer and now Mach 3 not working
    Been using my router for about 8 years with Mach 3
    My computer crashed and I got another one and software would load but work, can load bobcad file but will not run, jog or emergency stop does not work
    First computer I bought was a 32 bitt and thought that was the problem. bought a 64 bitt and have the same problem.
    The computer I am on right now will run Mach 3 but I just use it to test files and it is a 64 bitt computer
    Need some help on what to do or what is wrong.
    Milton
    Nov 2013
    Default Re: Computer crash-new computer and now Mach 3 not working
    what motion controller are you using?
    If you are using a parallel port you MUST use Windows 7 32 bit or earlier. Machs parallel port WILL NOT RUN on any 64bit OS,
    Windows 8 or Windows 10, and in most cases it wont run on a laptop.
    If you have a 64bit PC then you need an external motion controller like an Ethernet SmoothStepper or a UC300. Don't buy Chinese
    rubbish.
    Craig
    Jan 2005
    I am using Hobby cnc controller and I had a feeling that what you posted was the problem.
    Both of the computers that I got are running on Windows 10
    I have ordered another computer that is 32 bit and running with windows XP
    Thanks for your reply
    Milton
    Nov 2013
    OR get yourself an Ethernet SmoothStepper, there is a reason its called 'smooth stepper'.
    Craig
    Member Kenny Duval's Avatar
    Jan 2013
    United Stated
    Getting something like a smooth stepper would be my suggestion as well. The world is moving on and there is no need to have a PC running a 32 bit version of XP to cause the exact same issue down the road when it fails.
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    For Mach3 you ALWAYS have to have a spare board and HDD with full backup of a working one
    At least I do have.
    My config is small Intel miniITX board with integrated graphics, 2Gig RAM, 16 Gig CF card with XP SP3 on it and all CNC software that I use (Mach3 - Parallel Port, LaserGRBL - USB, PUMOTIX - LAN), secondary IDE HDD for swap file and jobs. Connected to LAN with no Internet access
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
