Need Help! Help G41 doesn't work for multiple offsets! - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 31 of 31
Thread: Help G41 doesn't work for multiple offsets!
  1. #25
    Member BehemothDT's Avatar
    Mar 2014
    Default Re: Help G41 doesn't work for multiple offsets!
    Quote Originally Posted by metalmayhem View Post
    Attachment 426828
    this is what I'm getting in mach 3
    Did you input the tool diameter 1.25" in the tool table for #120?
    If diameter is set at 0.0" mine looks like yours.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  2. #26
    Member metalmayhem's Avatar
    Jun 2018
    on my feet
    i was playing around with it and I see what you mean . I put 1.25 in the wear earlier , when I put it in diameter then it's pretty whacked out
  3. #27
    Jan 2005
    You would never put 1.25 in the wear dia that would mean the tool diameter would be 2.5 dia
    D the tool diameter=1.250 tool wear is only how much you want to add so if you added 0.010 this would add 0.010 to the diameter of the tool
    Mactec54
  4. #28
    Jun 2018
    on my feet
    tell me something I don't know
    I'm just trying to repeat what was suggested and I happened to put the suggested value in wear rather than diameter
  5. #29
    Mar 2003
    Shelby Township
    The Wear offset column in Mach3 doesn't do anything at all.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  6. #30
    Jun 2018
    on my feet
    I played around some and chopping up the code into sub routines for the finish paths resolves the problem on multiple work offsets
  7. #31
    Jan 2005
    Quote Originally Posted by ger21 View Post
    I don't know if it works or not I never use the wear offset
    But I do use a P value in the code and it work just fine
    Just did this for kicks and giggles these are just straight lines, and it works as programed what ever the P value is it will offset the tool by that amount
    G90 G17 G40 G80
    G21
    G54
    G0Z1.
    G0 X0 Y0.
    S1000 M3
    G1 G41 P0.05 Y.5 F25.
    X1.5
    Y.6
    X2.0
    G40 Y1.25
    M5
    M30
    Mactec54
