Need Help! Newbie here ....couple of questions
Results 1 to 1 of 1
Thread: Newbie here ....couple of questions
    Default Newbie here ....couple of questions
    Bit of back ground
    I have a old (1965) 3 axis Cincinnati
    Have installed nema 42 steppers
    And DM 2282S drivers
    I have this break out board from eBay
    https://www.ebay.com.au/itm/5-Axis-C...1294f4057613ab
    Problems
    I cannot figure which pins to set motors to
    2-3 is x
    4-5 is a
    6-7 is b
    8-9 is relay
    That’s all I can figure ..??
    I cannot get y or z to trigger
    Also when wired with all Neg as common and enable pos , Dir pos and Pul pos the driver goes straight in fault mode
    I did find the wiring on the net so not sure it’s correct
    Hope you guys can help
    John P
    Aug 2016
    Quote Originally Posted by Merlin65 View Post
    Bit of back ground
    Problems
    2-3 is x
    4-5 is a
    6-7 is b
    8-9 is relay
    John P
    Can you post the wiring diagram you have .
    On most boards the common can be set to supply the pos to step and dir . The active low in Mach for the step and dir pins turns the motor.
    That board also looks like it is driven by parallel port and the USB is probably only for power.
    Sent from my XT1635-01 using Tapatalk
