Need Help! 5 axis milling control
Results 1 to 3 of 3
Thread: 5 axis milling control
    Registered Germinal's Avatar
    Feb 2019
    Default 5 axis milling control
    Hi friends ... I'll ask you some questions;
    Is Mach 3 software sufficient to control a 5-axis cnc machine?
    Some mach3 control cards are sold on the market, are these cards directly operated with mach3 ?
    Or do I have to program these cards after I get these cards?
    Is the Soldicam or Fusion 360 + Mach3 software + Mach3 control card sufficient to run a 5-axis cnc?
    Thank you...
    Member hanermo's Avatar
    Aug 2004
    barcelona
    Default Re: 5 axis milling control
    mach3 will run 6 axis + spindle perfectly.
    the motion control cards need no programming.
    Jun 2015
    Sweden
    These can run up to 6 axis with Mach3:
    CNCdrive - motion controls
    No programming of the cards required.
