Mach crashes my computer
Results 1 to 12 of 12
Thread: Mach crashes my computer
    Jul 2009
    Default Mach crashes my computer
    When I goto load Mach 3 the computer locks up and I can not do anything. This happens when it tried to take control of the parallel port. I ran the driver test and all is good until it takes control and it freezes everything. I have also tried the "special" driver that comes with Mach3.
    Any ideas?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Go through the optimization list and see if it helps.
    http://www.machsupport.com/downloads...timization.txt
    UCCNC 2017 Screenset
    Registered GaryCorlew's Avatar
    Jan 2006
    Usa
    try leaving the parallel port unplugged from your bob till windows boots up then plug it back in, I have the same problem with mine and I have not had time to investigate any further yet, it only happens with one of my bob's
    Jul 2009
    none of that helps. Still locks up.
    Mar 2003
    Shelby Township
    What kind of PC, and what OS?
    Jul 2009
    It is a VIA EPIA Mini-ITX (EPIA-PD) the Chipsets are VIA CLE266 North Bridge and VIA VT8235 South Bridge. I am running a fresh install of XP.
  7. #7
    Jul 2009
    Going to try win 2k and see how that works out. Might have to run EMC2 but would rather run MACH if I can. Changing the motherboard is not an option.
  8. #8
    Jul 2009
    Wow it works with Windows 2000 Pro....
  9. #9
    Feb 2014
    Default Re: Mach crashes my computer
    Same problem here;
    Motherboard: VIA Epia M with C3 at 800MHz
    chipset: VIA Apollo CLE266 / VIA VT8235M
    Tried to put LPT in EPP mode in both version 1.7 and 1.9 (in BIOS), but no luck..
    [EDIT] Read somewhere that setting XP to "standard PC" instead of "ACPI PC" would fix this on the EPIA M 1000 Mhz motherboard, but it did not solve the problem om my 800 Mhz version.. [/EDIT]
    running fresh XP SP3, Did not try windows 2000 yet..
  10. #10
    Mar 2003
    Shelby Township
    Did you try the "Special Driver"?
    It's been a long time, but some PC's just won't run Mach3.
  11. #11
    Feb 2014
    Quote Originally Posted by ger21 View Post
    Did you try the "Special Driver"? It's been a long time, but some PC's just won't run Mach3.
    Yes, it's an old thread, but still useful for us XP users :-)
    And yes I've tried the special driver, but PC locks up as soon as test begins.
    Guess PC's with this VIA chipset should be avoided for using with Mach3. (or perhaps use a separate LPT card, i've got one on the way from China now to test that)
  12. #12
    Mar 2003
    Shelby Township
    Now that you mention it, i seem to recall the VIA chipsets were indeed the most problematic with Mach3.
