Need Help! MACH3 MachTurn not picking up "Index" on mini lathe
Results 1 to 4 of 4
Thread: MACH3 MachTurn not picking up "Index" on mini lathe
    Jan 2015
    Default MACH3 MachTurn not picking up "Index" on mini lathe
    I recently purchased a Harbor Freight Mini Lathe that someone converted and I am wanting to get a spindle index/tach set up to cut threads, etc.
    It is using Mach3 with a Gecko 540 running through a UCC100.
    I purchased a C3 Index pulse card and wired it in according to the diagram in the description. It has its own 5v power supply. When I turn the spindle, the LED on the card blinks properly. But I can't get it to pick up the index in Mach Turn. I have the output on the card wired to the #1 pin on the Gecko. I have made the Index active in MachTurn on Port 1 Pin 10 (diagram indicates that Pin 1 on Gecko is Pin 10) but when I go to the diagnostic page and roll the spindle around the "Index" light doesn't light up.
    Would anyone have any input on what I may be overlooking?
    Thank you in advance
    Jan 2018
    United Kingdom
    Quote Originally Posted by cdowns View Post
    Is there an actual sensor on the Spindle for the card to read?.
    Jan 2015
    Default Re: MACH3 MachTurn not picking up "Index" on mini lathe
    Yes, put an index pulse card with slotted disc for pick up, I have just found out that UC100 doesn't support Index in Mach 3 turn. Looking into a wire around for that now. Any ideas?
    Sep 2005
    Indonesia
    wait for uccnc turn software released ...
