MACH3 software DRO vs actual position issue please help!!!!!!!!!
Results 1 to 3 of 3
Thread: MACH3 software DRO vs actual position issue please help!!!!!!!!!
    Member OasisCustoms's Avatar
    Mar 2021
    Angry MACH3 software DRO vs actual position issue please help!!!!!!!!!
    Hello, I am a newbie at lathes, I've spent most of my short experience time on CNC Mills, I just purchased an American Bridgemill and I'm having some difficulties. I'm going to explain this the best I can.
    Long story short, I'm trying to cut a diameter using the jog. My numbers on the MACH 3 DRO do not match the actual diameter of the part that I just turned. All settings are on Diameter mode. If I cut .02 of a .5 diameter the MACH 3 DRO shows me .480 while the part diameter measures .460. Is there any way to see the true number on the MACH 3 DRO. i.e. if I cut .02 radius the DRO shows a .04 Diameter change?
    I figure this is a setting someplace in the Mach3 program how do I change this?
    Thank You.
    Oasis Custom Firearms
    Oasis Custom Firearms – Selling You Peace of Mind
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: MACH3 software DRO vs actual position issue please help!!!!!!!!!
    Maybe your steps/unit setting is wrong?
    UCCNC 2017 Screenset
    Mar 2021
    I followed the setup manual word for word for steps per unit in motor tuning. If I move incremental (G91) with the MDI .01 it does move .01 on the MACH 3 DRO and the manual DRO. Is that correct?
