Mach3 Turn Newbie
Results 1 to 2 of 2
Thread: Mach3 Turn Newbie
    pjmaud's Avatar
    Feb 2021
    Default Mach3 Turn Newbie
    I have just converted my Sieg SC2 Mini Lathe to CNC using Mach3 Turn and would be happy to share the details of my conversion, just ask if you are interested.
    I would like to know if Mach3 Turn supports polar coordinates in the XZ plane? I am trying to turn a tapered cone and have tried the "wizard" which seemed OK at first then jammed part way through. Restarting within the Gcode is beyond my capability so I would use diameter and angle in Polar cocrdinates to finish it off
    I have tried various combinations of G18 and G16 but only seem to get absolute coordinate movement.
    Does anyone know if this can be done?
    If so what are the settings and the syntax of the command line?
    Any help would be appreciated.
    Mar 2015
    Default Re: Mach3 Turn Newbie
    Check out Ezilathe in the downloads/others area. Should do the job easily.
Mach3 Turn Newbie
Mach3 Turn Newbie
