Need Help! Extra Circles In Mach3turn. Incorrect NC Display
Results 1 to 3 of 3
Thread: Extra Circles In Mach3turn. Incorrect NC Display
    Activation process Actor28's Avatar
    Dec 2018
    Default Extra Circles In Mach3turn. Incorrect NC Display
    In Mach3Turn the NC is not displayed correctly: extra circles in the NC display window.
    Mach3 completes the arc to the circle.
    How to fix it?
    The text of the nc file in the application
    Thank you!
    Attached Thumbnails Attached Thumbnails Extra Circles In Mach3turn. Incorrect NC Display-11-jpg   Extra Circles In Mach3turn. Incorrect NC Display-12-jpg
    Attached Files Attached Files
    Member anycolorsmith's Avatar
    Nov 2020
    Default Re: Extra Circles In Mach3turn. Incorrect NC Display
    In several lines it is required to replace G2 with G3. And check the settings for processing arcs. It's not a problem Mach. See correct file in attach. I have it displayed correctly. You speak russian? Sent me PM
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Actor28 View Post
    How to fix it?
    Thank you!
    Try this in the configuration page change the I/J mode
    Attached Thumbnails Attached Thumbnails Extra Circles In Mach3turn. Incorrect NC Display-ij-turn-png
    Mactec54
