G52 offsets not shown in mach3 screen
Results 1 to 4 of 4
Thread: G52 offsets not shown in mach3 screen
    Mar 2016
    Brazil
    Default G52 offsets not shown in mach3 screen
    Hi! I’m still learning gcode and cnc and I’m using Mach3 wizards for my small jobs.
    I’m doing a series of grooves in a part, and I edited a wizard generated code, aleays in the same X dimensions, but I change only the z value for each groove. So I use G52 to each offset and I copy and paste always the same code for each groove, only change the g52 value for Z.
    It works normally, but in the mach3 screen, only one groove is drawn, not the series of grooves, side by side. As all grooves were made over each other. Is there a way to fix it so all my grooves are shown on the screen?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: G52 offsets not shown in mach3 screen
    No, it's a bug in Mach3.
    UCCNC 2017 Screenset
    Jun 2010
    +1 to Gerry.
    It is annoying of course, but the actual cutter path is OK.
    Cheers
    Roger
    Mar 2003
    Shelby Township
    Same thing happens with work offsets, if I recall correctly.
