Hello, I would like to add a Y axis to Mach3 turn screen set. Anyone know if a screen set is available to add a third axis to Mach3 Turn? Thank you.Similar Threads: Mach3 soft limit lathe Shopmaster Mill TurnNeed Help!- Homing MACH3 Turn (lathe) Andre I need help, Partmaster Lathe V13 and Mach3 Turn --- tool changer questions need help bobcad lathe mach3 turnNeed Help!- need help bobcad lathe mach3 turn threading
Relatively easy to add an extra axis using mach3screen.exe. nearly all you need is there already, you just need to add a couple of visual components like hero's.
My not ended screenset. Made in Mach3 Screen for lathe with position spindle.
View Tag Cloud
Forum Rules
