In my experience, stopping and resuming a program in Mach3 is pretty much playing Russian roulette. Most of the time it works, but sometimes it just blows its brains out.
I have been running Mach 3 for years and sometimes I need to stop during a cut process or may get a false Limit trip. So I will deal with my issue and use the "RUN FROM HERE" feature and away I go! So sometimes I have had the issue when using this feature and I hit "Cycle Start" the "Z"- Axis for reasons I do not understand will travel up to Max travel and hit the Limit switch. Can someone tell me why this is happening and how to stop this?
Steve in Maine
It might have something to do with your Safe Z settings.
UCCNC 2017 Screenset
It has never worked for me. I don't try it now.
Cheers
Roger
It's worked fine for me every time I've ever used it.
Might be an ESS issue, as I use the parallel port.
Thats one of the reasons I switched to Mach4, 3 has those little quirks. Its Not Warp9 ESS as it does great on 4.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
Just because it works in Mach4 does not mean it works in Mach3. Two different programs, with different plugins and firmware for each.Its Not Warp9 ESS as it does great on 4.
