Need Help! Touch Off UI Find Center Not Working
Results 1 to 3 of 3
Thread: Touch Off UI Find Center Not Working
    Member Dbl_Tap's Avatar
    May 2011
    Question Touch Off UI Find Center Not Working
    I posted this in the Newfangled forum but haven't had a reply so hoping the brain trust here can help.
    Probing works fine for one Axis. I can zero my Z, find the edge of X & Y but if I try using the "Find Center" in my center finding touchplate it will move to the X-, contact the plate, then make a small move in the X+ direction and then disables Mach.
    This is what History shows.
    "X axis is performing a touch move.
    ESS starting Probe 0
    ESS: Successful Probe0 Strike. Probing finished.
    ERROR: No contact with probe"
    I have an ESS and have "Probing Failure Disables Mach" deselected. I have also tried with it enabled with no change in result.
    My grounding of the system is very good and have no noise issues. I did try adding noise filtering in the ESS configs but there was not change. If it was noise I would also think I would have issues with other touch probe functions but all work for a single function.
    I've looked at all the topics I can find and I may have missed the answer so if anyone can help I would greatly appreciate it.
    Chris Livingston
    Tigard, OR USA
    Member phomann's Avatar
    Aug 2005
    Default Re: Touch Off UI Find Center Not Working
    I’m not sure what probing macros you are using, but what seems to be happening is that there is a setting that defines a distance limit where if the probe is not activated, the probe routine is aborted.
    If that is the case, you need to set that limit larger so that it is greater than the distance being measured.
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com
    May 2011
    I'm using the Mach4 built in ones. I guess I didn't think of checking the settings internally programmed to that button
    Chris Livingston
    Tigard, OR USA
