the HLFB is usually used for signaling a fault to the controller, say an overload condition or a following error. If you want to use the HLFB for some other purpose the you would
lose the ability to signal a fault. Are you sure you want to do that?
You may have seen a button <Axis Limits Override>. May I suggest try using that, I believe it will disable the Limit switches and you will be able to use hardstops. Thereafter you'd
turn the Limits back on.
If that works then with a little scripting you could automate it.
Craig
