Mach 4 Software
Results 1 to 6 of 6
Thread: Mach 4 Software
    Member industrymachinedesign's Avatar
    Aug 2020
    Default Mach 4 Software
    Is anyone using Mach 4 for an industrial machine? Wire bending or machining?
    Nov 2013
    Default Re: Mach 4 Software
    I use Mach4Hobby and have done for eight years.
    I use it daily for making small parts (for automotive instruments) and isolation routed circuit boards. It is not industrial, but I do make a living from it.
    I have also done some retrofits to various machines, a couple of plasma tables, a lathe and most recently a guillotine. My experience is that Mach4 is quite flexible and useful
    for retrofit purposes, and is very modestly priced relative to genuine industrial controllers.
    Is there a particular feature or operation that you need it to perform? Mach4 is well suited to and pretty much ready to go with up to six axis mills.
    Craig
    Aug 2020
    Looking at a 6 axis wire bending machine. Thank you for your reply.
    Tom
    Nov 2013
    we used to use it, but in the end of the year my boss said that we should discontinue using standard or typical software because of the competition.
    That seems a bit pointless, firstly your competitors have access to 'standard and typical software' whatever your solution, and they will pay a very small fraction of what you will pay
    to re-invent the wheel because a large part of the cost that you face to develop your own solution is just to redo what is already available elsewhere, in this instance Mach4.
    Any and all code over and above the standard issue Mach4 code is compiled and so on one can copy that.
    One of the driving forces behind the design and implementation of Mach4 was that it could be used by OEM machine builders to take and adapt to their specific machine and make a distinct
    and unique product.That is the reason for the extensive scripting capabilities, the API and the built in GUI editor. Of course those features are just as valuable to a hobbyist with a one off machine or
    a manufacturer whom produces hundreds of machines.
    Craig
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    East Tennessee
    Craig, I agree with you.
    Unfortunately, in this case the message you are replying to was posted by a spammer. He had a pattern of hiding spam links in text that may or may not represent what he actually thinks. Its more or less just cover for his spam links.
    He has been banned as a spammer, so his posts have been removed. That somewhat disrupts the flow of the thread, but that is better than leaving spam posts in place.
    And while it may not be apparent, this thread was the target of a second spammer, today. That reopened the thread but he has also been banned and his post removed. So I decided to post an explanation of the disruption in the thread reply sequence.
    Nov 2013
    dirty damn bloody SPAMMER.....kick him in the bollocks I say
    Craig
Mach 4 Software
Mach 4 Software
