Problem Mach 4 reinstall preview issue
Results 1 to 3 of 3
Thread: Mach 4 reinstall preview issue
    Jun 2017
    Default Mach 4 reinstall preview issue
    I had a computer issue & had to reinstall Mach 4 for my Avid CNC Pro router, everything works fine now but the preview on the right is very hard to see, the lines that show my part, the current X-Y location & cutting boarders. It is like the lines need to be thicker.
    Thanks for your help in advance
    Gary
    Nov 2013
    Default Re: Mach 4 reinstall preview issue
    the ToolPath Pane is zoomable. Have you tried to do so? Sometimes a refresh on the Toolpath tab or disengaging the travel limits view feature will allow Mach to
    more appropriately zoom and dsiplay the toolpath.
    Craig
    Jun 2017
    Craig
    The width of the line doesn't change much based on zoom level. I'll check the toolpath tab next week when I'm back in the shop.
    Thank you
    Gary
    Member burystreak's Avatar
    Jun 2022
    The width of the line varies little depending on the zoom level. When I return to the store next week, I'll check the toolpath tab. slime rancher 2
