Mach 4 Surface map wizzard
Results 1 to 8 of 8
Thread: Mach 4 Surface map wizzard
    Apr 2018
    Default Mach 4 Surface map wizzard
    Hello all,
    I'm trying to get mach 4 surface map wizard to work. My machine does the probing and I load the surface map but it doesn't make a difference. The Z axis doesn't make any sort of adjustments. I'm using ESS that came with my Avid plug and play kit (CRP800-00E-8). That wizard is really the only reason I upgraded to mach 4. I engrave on uneven surfaces. Any advice would be appreciated.
    Nov 2013
    Default Re: Mach 4 Surface map wizzard
    I use the ESS and Mach4 and have done for years.
    I have tried the Surface Wizard and it works as expected....although I think its a less than optimum choice for what you want to do.
    The Surface Wizard is meant to probe the table and then cause the machine to make minor Z axis adjustments as it runs otherwise standard Gcode.
    The probing routine is rather slow, and was really intended that it be done once then left alone, until say the machine has undergone some
    maintenance or re-build.
    One of the main uses for my machine is isolation routing of PCBs. Very accurate Z axis movements are critical to the success of isolation routing
    and for this purpose I use Autoleveller, a freeware software utility. It generates Gcode to probe a surface that is being worked on, records the probe
    results data and THEN modifies the Gcode job by minor alterations to the Z axis movements. I've been using it for six years and would be lost without it.
    Its very much intended to be used and re-used at each new job.
    Autoleveller – CNC Millings, Levelled
    Craig
    Member CitizenOfDreams's Avatar
    Nov 2012
    +1 for Autoleveller. I have also been using it for many years for PCB making and engraving. I kind of wish something like that was integrated into Mach3, but I don't think the Mach4 wizard is what I want.
    Apr 2018
    Hello Craig, I will certainly give Autoleveller a go. I just downloaded it and see it doesn't have an option for Mach 4. Do I just use Mach 3 for controller or do I have to do something with custom?
    Nov 2013
    Within the exception I noted above Autoleveller and Mach4's Surface Wizard perform identically.
    I've been using the combination of Mach4 AND Autoleveller for six years....so it does work. If you do some research you will find I posted
    two macros M40 and M41 written in Lua that allows AutolevellerAE to save probe data to a file using Mach4.
    Craig
    Apr 2018
    Craig
    Hello Craig, thank you so much for your reply. Researching Autoleveller and trying to figure out how to use it has been all I've been working on today And thank you for the work you have done. I have the Macros loaded. I was asking about within AutolevellerAE which controller do I select for mach 4 as Mach 4 isn't listed.
    I'm just a simple guy at his wits end. Please forgive me for asking stupid things.
    Attached Thumbnails Attached Thumbnails Mach 4 Surface map wizzard-alae-jpg
  7. #7
    Nov 2013
    just use Mach3, its just the Gcode generator option, and as you know Mach3 and Mach4 Gcode are nearly identical.
    Craig
  8. #8
    Apr 2018
    Well, that worked. I had a successful probe run. Tomorrow I'll do a full run and see how my engraving comes out. Thanks for all your help.
