I’m using Mach 4 and driving pokeys57cnc via Ethernet cable.
So I had to wire a pendant directly to the pokeys board in order to go Ethernet. Vista cnc pendants don’t play well with Ethernet for some reason and usb works but is not a smooth way to drive a controller
So the problem is that every time I load Mach I need to reload (press the load setting button) in the pokeys plugin pendant page. If not the X axis kind of floats with any axis move.
Pokeys doesn’t really support Mach 4 so no help there. Very solid and smooth controller BTW.
Any suggestions?
