Bluetooth android app for Mach4
Results 1 to 7 of 7
Thread: Bluetooth android app for Mach4
    Member cnctutor's Avatar
    Nov 2019
    Default Bluetooth android app for Mach4
    hello to all,
    I have developed an Android app for control Mach4 with bluetooth.
    You can find it in Google play store with the name of
    "CNC Bluetooth for Mach 4" or click this link https://play.google.com/store/apps/d...etoothformach4
    Available functions:
    -Jog functions
    -Start / Stop / Feed Hold
    -Override feed
    -Start and stop spindle
    -Home reference
    To work you must have the following prerequisites:
    -Android version 9 or higher (previous versions of the application cannot be installed as they
    do not have some features that are present only from version 9 onwards)
    -A PC with bluetooth and a version of Mach 4 installed
    No need to install any additional software on your PC!
    At this link you can find a configuration guide
    https://drive.google.com/file/d/1g_C...VtBnQTohk/view
    I'm waiting for comments
    Mar 2017
    Default Re: Bluetooth android app for Mach4
    This sounds fabulous. I will have to try it.
    Have you thought about an app for a pendant? There are several wireless pendants on the market but none that have a plugin for Mach4. I am sure that the pendants use Bluetooth and emulate a HID device.
    Nov 2019
    let me know what you think when you try it.
    Yes i think that is it possible add a pendant page...I will work on it.
    My application use HID bluetooth (only for Android 9 o major) for simulate a wireless keyboard so is not necessary any additional plugin for Mach4...
    Practically this application as it is made would also work with Mach3, but I think I create a separate application available shortly ...
    Nov 2013
    a CNC machine that is controlled wirelessly.....and you think this is a good idea???
    I would suspect you are a programmer and have absolutely no maching exeprience.
    Craig
    Nov 2019
    Craig
    I think it's not dangerous if you're a good programmer! as for my experience in machining look at the attached photos and let me know if I have enough
    Attached Thumbnails Attached Thumbnails Bluetooth android app for Mach4-img-20180427-wa0001-jpg   Bluetooth android app for Mach4-img_20190206_130123-jpg
    Mar 2017
    I think wireless is not as bad as you make it out to be. I use a wireless keyboard and mouse and there are lots of folks that do that.
    I use a pendant on my machine and would like for it to be wireless. I never start/stop a cycle with the pendant but it is vary handy to use to jog, zero, position, and setup a cycle.
    I would never reach for the E-Stop button on a pendant, I would go for the big red button that is wired directly to the machine right in front of me.
    And, yes, I do some programming and machining, I am just your average Joe (PUNN).
    Thanks.
  7. #7
    Mar 2016
    Quote Originally Posted by cnctutor View Post
    hello to all,
    -Jog functions
    -Override feed
    -Home reference
    Configuration guide no longer links to anything. Help?
