Need Help! Mach4 Outside cuts to BIG,
Results 1 to 6 of 6
Thread: Mach4 Outside cuts to BIG,
    Aug 2004
    Default Mach4 Outside cuts to BIG,
    Hello everyone
    I been having problems with this for a while now, seams to come and go
    I am running Mach 4 with a SmothStepper ESS
    when i try to cut outside a part it is always about 1/8 to big
    I messed around with this all day and cant figure it out for the life of me,
    don't matter what i try it is always the same,
    I tried to remove g43 and g49 my tool table are all zeros
    but when it cuts something on the inside, it cuts the right size, just on outside cuts
    Anyone have any ideas ??
    I attached my gcode
    Attached Files Attached Files
    Member awerby's Avatar
    Apr 2004
    Default Re: Mach4 Outside cuts to BIG,
    Are you using a CAM program to generate these toolpaths? If so, which one? It sounds like it's applying a tool offset which is incorrect for the tool you're using. What's the diameter of that tool?
    May 2005
    canada
    That program has so many tiny G3 moves it makes me dizzy. Any decent backplot software will show what it should be, Camotics isn't great and that's all I've got on this computer.
    Max X 23.125
    -Min X 0.875
    =22.25 subtracting 0.25 em makes a 22" wide part. Sound right ?
    My eagle eye may have missed a X limit somewhere.
    Anyone who says "It only goes together one way" has no imagination.
    Member machinehop5's Avatar
    Aug 2009
    I agree.. your CAM program is doing it..... a Tool Diameter setting or cutting condition statement.
    Mach4 Outside cuts to BIG,-cut3-screenshot-jpg
    Aug 2004
    I used Inventor HSM 2019, the part is 22 inch wide, with a 1/4 in tool, I think i have some studding to do hehe, but i been using this for years and not have a problem
    I adjusted the steps per inch, make sure that was right and i think i might be losing some steps
    I put some new motors not to long ago, and i think they are total junk
    May 2005
    canada
    Oops I now notice you signed up here 15+ years ago so this isn't your first rodeo.
    When a problem doesn't fit logic or theory sometimes all we're left with is checking connections and swapping out parts. Hopefully it all works out some way.
    re my comment on the many little arcs: the corner arcs look like standard fillets but that's just a guess. Only you know the exact part geometry or how it was created.
    And if it works it works, it was just an observation.
