New Machine Build How do I control the feedrate/jogging speed arrows with a keyboard?
Results 1 to 2 of 2
Thread: How do I control the feedrate/jogging speed arrows with a keyboard?
    Nov 2015
    Default How do I control the feedrate/jogging speed arrows with a keyboard?
    Greetings,
    I am trying to control the arrow keys that will increase or decrease the jog speed with a keyboard. I'm quite stuck and could use some help. Thanks!
    Member awerby's Avatar
    Apr 2004
    Default Re: How do I control the feedrate/jogging speed arrows with a keyboard?
    Normally, the jogging feedrates are set in Motor Tuning when you indicate velocity. If it goes a lot slower than that, you might have a slow jog feedrate active. Hit the Tab key and see what it says under "Slow Jog". If it's less than 100%, you can change it with the slider. If you like having a slow jog rate sometimes, you can set it to a lower percentage, and hold down the shift key when you want to jog fast, which should make it revert to the master velocity.
