Hi guys.
After epic work, I am very close to having my Mach 4 contolled router working correctly.
I am setting up my new 4x4 router, which is built with all CNCRP parts and their Plug and Play ESS control box.
I am running a licenced copy of Mach4 which I bought from CNCRP.
My y axis has two NEMA 34 motors. When facing the machine, the Y- is on the left and the Y+(Slaved) is on the right.
When I press the "Home All Axis" the Z and X axis home correctly and then the Y axis moves toward the front of the machine.
The Y axis trips the Y- limit switch and the gantry stops. The Y- motor stops. However, the slaved Y+ axis motor keeps turning and I have to hit the e-stop to turn it off.
Now for the limit switches. I have a Y- and Y+ limit switch positioned on the front and back of the left side of the y axis.
On the front right hand side of the machine, I have the y- slave switch connected to the "Slaved" connector on the CNCRP ESS box.
While my machine has linear rails for the axis, I followed this diagram from CNCRP:
When I look at the the Diagnostics Tab, the y- and y- slaved sensors have been tripped. So the sensors do seem to be working.
I tried removing the sensor on the front right that slaved y motor moves toward. But that did not stop the the y slaved motor from continuing to turn when the gantry homes to the front.
Can anyone suggest why the slaved y axis motor does not stop when it reaches home? Would it suggest it is not receiving the instruction to stop? If so,how would I correct this?
I am a total newbie so simple, step by step info is appreciated.
Thank you!
David
