Need Help! Mach 4 and ESS Limit/Homing Configuration
Results 1 to 7 of 7
Thread: Mach 4 and ESS Limit/Homing Configuration
    Feb 2012
    Default Mach 4 and ESS Limit/Homing Configuration
    G'day all,
    When setting up the Limits and Homing, specifically soft limits in Mach 3, I had the last 25mm before "0" home, travelling at 20% of nominal speed.
    How do I achieve the same in Mach 4 with the ESS? I've had a look at the Limits/Home tab in the ESS plug in, but am not sure about the values to enter regarding the "unit/minute" column. They are set to "1" at the moment. Is that that "1mm/minute" and for how many mm preceding "home" would it be activated?
    Ray
    Nov 2013
    Default Re: Mach 4 and ESS Limit/Homing Configuration
    That is the homing speed, it does not go fast until it gets close and then slow down. When you think about it....it can't. If it knew where
    the home switch is and slowed down 25mm before it got there then why are you bothering to reference your machine?.
    The whole point of referencing is to inform Mach of it location relative to the home switches. Thereafter and for the remainder of the session Mach
    knows where it is by cumulative motion.
    The setting in the ESS is the speed the axis will travel when executing a home command. It does not have a fast phase. Note that you approach
    at one speed but can back off at another.
    Thus you might approach the home switch at 300mm/min, a bit quick for repeatable accuracy, but you can back off until the home switch deactivates
    at a much lower and therefore accurate rate of 50 mm/min.
    Craig
    Feb 2018
    I'm working on building my 2nd machine, and I have been looking for pretty much the same thing.
    What I have found so far suggests that it can be done using a custom stript for the homing button. But if it IS possible. You will likely need extra limit switches to let mach know it's close to home and needs to slow down. I would love to be able to rapid home and slow to a crawl for the last half inch of travel! If I figure it out here. I'll let you know what I came up with.
    "What I DO have is a GED and a Give 'em Hell attitude, and I'll figure it out" -Dean Winchester
    Nov 2013
    Some industrial machines have just exactly that arrangement....extra switches called pre-limit switches to inform the controller that a hard
    limit is approaching and to reduce speed to avoid crashing into it.
    Another possibility is to use the latest generation AC servos with multi-turn absolute encoders.
    For example DMM have introduced a new encoder, a 32 bit absolute, arranged as 16 bits (65536) turns from home and 16 bits
    (1/65536 th) within that one turn. These positions are battery backed so that if you turn your machine off and come back later and turn
    it on it remembers where it was and can start from there without having to do the whole home/reference thing. Very nice but probably
    an expensive way to get out of homing your machine. Is it really that painful/slow/arduous?
    Craig
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    The servo drive may know where it is, but how do you tell Mach where it is?
    UCCNC 2017 Screenset
    Nov 2013
    Hi Gerry,
    good question, I don't know, I don't have such a servo to experiment with.
    I presume that once the servo drive is powered up the position is reported and held by the drive. The position can be read by Mach.
    Inducing Mach to overwrite its machine coordinates is not trivial. I would attempt to have Mach 'home in place' but apply the home offset as provided
    by the drives..
    Craig
  7. #7
    Oct 2016
    Sweden
    Quote Originally Posted by nr0x View Post
    I don't know what the homing routine on the ESS looks like but I have solved this differently on my 3040 which use limit switches for homing. I use the Darwin parallel port plug-in and it has no options for back-off.
    I made a custom script for the homing button that performs a first rapid homing according to homing speeds in control config. This speed is as high as I dare to run without crashing into the switches. It's far from accurately homed.
    Then I back-off enough to clear the limit switches and programmatically change the homing speeds to a much lower speed and perform a second accurate homing.
    Finally I programmatically restore the homing speeds to the high speeds I started with.
    The script has not been tested with any other controller but if you are interested in trying it or get some inspiration for a similar solution you can have a look at it at https://github.com/perhof/Mach4-scripts
    A different option could be a script that reverse the homing direction in the settings to home backwards after a first high speed homing but it would also need to invert the switch levels to make them activate when they open again and I haven't looked into those settings so I don't know if it can be done.
    Besides, I prefer to change as few settings as possible because I'm afraid of what would happen to my settings if the application would crash while running with the temporary settings.
    The worst thing that could happen with my script now is that I would get stuck with very low homing speeds which at least is safe.
