Im experienced some issue with my CNC,
thats a Chinese machine controlled by a Gecko G540 and Mach4 (using Darwin plugin) .
Im experienced 2 issues:
1. My axis wont automatically stops when i press the limit/ homing switches while moving or jogging.
Each limit configured to trigger the ++ limit, -- limit and Home (confirmed by the diagnostics tab wiring is OK)
Also- if i press the limit switch while IDLE and then try to jog- then i get the error message of "Limit switch tripped".
2. "Ref all home" wont move any of the axis.
what should i configure in order to resolve the issues and make things work work properly?
