- trace out and create a *.dxf file for a tote bag
took a diagram of a sunflower printed it and traced it using logic trace 2018 to create the *.dxf file required to print it on vinyl and heat transfer the image to a canvas tote bag
https://stankern.vids.io/videos/069e...for-a-tote-bag
Re: trace out and create a *.dxf file for a tote bag
When you migrate data using Google Workspace Migration for Microsoft Outlook, a trace file is created that records each step of the migration. If errors occur during the import, this file helps you determine at what stage they occurred. This information is typically used by Google Technical Support. For example, suppose the log message indicates that the error is related to a specific porting module. In that case, Google developers can quickly fix the problem. But for my problem, the developers did not respond at all. Thus, I also could not transfer my image to the tote bag. So I had to use https://www.interplas.com/halloween-bags, which had Halloween-inspired bags in stock. Just what I needed.
- You may not post replies
- You may not edit your posts
Forum Rules
