- logic trace 2018 digitizing a clock diagram and building the project
I found a small diagram on a unique clock dial and used
logic trace 2018 to digitize the diagram and enlarge it
full size
for a large clock project .
The dial was cut by a plasma operator and the wood parts were cut with the cnc
I also cut he file on a CO2 laser to show that the file is easily used
by either machine
part1 took a small diagram of a clock dial and digitized it
part 2 this is the plasma cut of the dial and cnc machining
- You may not post replies
- You may not edit your posts
Forum Rules
