Logic Trace 2018 file that I will show a simple node edit
Results 1 to 1 of 1
Thread: Logic Trace 2018 file that I will show a simple node edit
    Member woodman08's Avatar
    Oct 2007
    canada
    Default Logic Trace 2018 file that I will show a simple node edit
    I had digitized a small diagram of a wren (bird) and I wanted to show how easy it is to edit the nodes if required
    Attached Thumbnails Attached Thumbnails Logic Trace 2018 file that I will show a simple node edit-wren-jpg   Logic Trace 2018 file that I will show a simple node edit-wren-nodes-jpg
