Need Help! LMS 3990 / HeavyMetalCNC conversion - backlash problem.
Results 1 to 4 of 4
Thread: LMS 3990 / HeavyMetalCNC conversion - backlash problem.
    Jan 2017
    Default LMS 3990 / HeavyMetalCNC conversion - backlash problem.
    LMS 3990 mill with the HeavyMetalCNC covnersion kit - but this isn't necessarily kit/mill specific
    (I have also asked HeavyMetalCNC for advice, but while I wait for a response, I though I would ask for some opinions here.)
    I have finally installed everything, dialed in all my axes, and have no binding and smooth moves.
    BUT – I have a big backlash problem on my Y-axis.
    X and Z – both have about a half a thou of backlash. Y – has .0331 !!!
    I tore everything down, set the Y axis gib perfectly, reinstalled the Y ballscrew and nut, and reattached everything to the frame. There is zero detectable play anywhere in the mechanical system. But when driving the axis – there is .0331 measurable backlash.
    If I tape a flag onto the stepper shaft, .0331 equates to about 1/8th of a turn before the ballnut engages. At 1/16th microstepping – that is about 400 steps…
    Test procedures -
    I measured by manually taking up the backlash, setting a test dial indicator to zero – then commanding a move away from zero, and return to zero – adjust the values until the dial does not move at all when taking up the backlash.
    i.e.
    -G0 Y -0.0331
    -G04 1000 (pause for a second so I can see the dial)
    -G0 Y0
    .0331 – needle does not move <- taking up the backlash in both directions.
    .0332 – needle moves a thou, returns to zero <- takes up the backlash, moves 1 thou
    .0431 – needle moves to 10 thou, returns to zero <- takes up the backlash, moves 10 thou
    I didn’t take any pictures or video, but I can if it will help explain better. (I am a total noob.)
    So I believe it to be entirely a ballnut/ballscrew issue – don’t know which of the two or a combination of both.
    What do you suggest?
    -Send the ballnut ballscrew back to vendor, and see if they can pre-load it better?
    -Try to pre-load it myself? (I don’t know how, or what size balls, etc…)
    -Buy a new ballnut/ballscrew pair, and hope they perform better? (X and Z are fine – so it may just be a one-off part issue)
    -Something else that I don’t know about that I can adjust?
    Sep 2008
    Default Re: LMS 3990 / HeavyMetalCNC conversion - backlash problem.
    I used to have the same machine, check the thrust ball bearing on the Y Axis bracket, make
    sure that isn't the cause of the backlash.
    Just a thought.
    Larry
    Jan 2017
    Thank you - In the HeavyMetalCNC kit, it comes with two 608 style ball bearings (axial, not thrust), and they don't have any detectable axial motion. The screw position is very rigid.
    Jan 2017
    Update: I heard back very quickly from Bruce at HeavyMetalCNC, and he offered to redo the preload on the ballnut for me, so I am disassembling one more time....
    On the bright side, I can tear down the mill in 20 minutes now, after all the practice I have gotten.
