Patient expert needed for newb RTAPI error
Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Patient expert needed for newb RTAPI error
    Jun 2008
    Default Patient expert needed for newb RTAPI error
    I'm a complete newb trying to install EMC2 into Ubuntu 8.04 Hardy Heron to control a homebuilt gantry router.
    Ubuntu runs well, and installed easily on a separate hard drive on a 2.0 Ghz Sempron 3400+ Emachines desktop with 3Gb of RAM.
    I tried first to install EMC2 separately, then also with the EMC2-Ubuntu Live CD ISO image burned onto a CD.
    Same error both times: it seem I get a RTAPI error / segmentation error which I have no idea how to solve.
    All input welcome - Thanks
    error text follows:
    Print file information:
    RUN_IN_PLACE=no
    EMC2_DIR=
    EMC2_BIN_DIR=/usr/bin
    EMC2_TCL_DIR=/usr/share/emc/tcl
    EMC2_SCRIPT_DIR=
    EMC2_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/emc2
    EMC2_CONFIG_DIR=
    EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
    INIVAR=/usr/bin/inivar
    HALCMD=/usr/bin/halcmd
    EMC2_EMCSH=/usr/bin/emcsh
    EMC2_IOSH=/usr/bin/iosh
    EMC2 - 2.2.5
    Machine configuration directory is '/home/david/emc2/configs/sim'
    Machine configuration file is 'tkemc.ini'
    INIFILE=/home/david/emc2/configs/sim/tkemc.ini
    PARAMETER_FILE=sim.var
    EMCMOT=motmod
    EMCIO=io
    TASK=milltask
    HALUI=
    DISPLAY=tkemc
    NML_FILE=emc.nml
    Starting EMC2...
    Starting EMC2 server program: emcsvr
    Loading Real Time OS, RTAPI, and HAL_LIB modules
    Realtime system did not load
    Shutting down and cleaning up EMC2...
    Killing task emcsvr, PID=5226
    Removing HAL_LIB, RTAPI, and Real Time OS modules
    Removing NML shared memory segments
    Cleanup done
    Kernel message information:
    [ 0.000000] Linux version 2.6.24-16-rtai (root@dana-laptop) (gcc version 4.2.3 (Ubuntu 4.2.3-2ubuntu7)) #1 Sun Apr 13 17:50:16 EEST 2008 (Ubuntu 2.6.24-12.22-generic)
    [ 0.000000] BIOS-provided physical RAM map:
    [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
    [ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
    [ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
    [ 0.000000] BIOS-e820: 0000000000100000 - 0000000077ee0000 (usable)
    [ 0.000000] BIOS-e820: 0000000077ee0000 - 0000000077ee3000 (ACPI NVS)
    [ 0.000000] BIOS-e820: 0000000077ee3000 - 0000000077ef0000 (ACPI data)
    [ 0.000000] BIOS-e820: 0000000077ef0000 - 0000000077f00000 (reserved)
    [ 0.000000] BIOS-e820: 0000000078000000 - 0000000080000000 (reserved)
    [ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
    [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
    [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
    [ 0.000000] BIOS-e820: 00000000fefffc00 - 00000000ff000000 (reserved)
    [ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
    [ 0.000000] 1022MB HIGHMEM available.
    [ 0.000000] 896MB LOWMEM available.
    [ 0.000000] Entering add_active_range(0, 0, 491232) 0 entries of 256 used
    [ 0.000000] Zone PFN ranges:
    [ 0.000000] DMA 0 -> 4096
    [ 0.000000] Normal 4096 -> 229376
    [ 0.000000] HighMem 229376 -> 491232
    [ 0.000000] Movable zone start PFN for each node
    [ 0.000000] early_node_map[1] active PFN ranges
    [ 0.000000] 0: 0 -> 491232
    [ 0.000000] On node 0 totalpages: 491232
    [ 0.000000] DMA zone: 32 pages used for memmap
    [ 0.000000] DMA zone: 0 pages reserved
    [ 0.000000] DMA zone: 4064 pages, LIFO batch:0
    [ 0.000000] Normal zone: 1760 pages used for memmap
    [ 0.000000] Normal zone: 223520 pages, LIFO batch:31
    [ 0.000000] HighMem zone: 2045 pages used for memmap
    [ 0.000000] HighMem zone: 259811 pages, LIFO batch:31
    [ 0.000000] Movable zone: 0 pages used for memmap
    [ 0.000000] DMI 2.3 present.
    [ 0.000000] Allocating PCI resources starting at 88000000 (gap: 80000000:60000000)
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 487395
    [ 0.000000] Kernel command line: root=UUID=ba0c2ae3-e944-457c-894d-be986c9198d7 ro quiet splash
    [ 0.000000] Enabling fast FPU save and restore... done.
    [ 0.000000] Enabling unmasked SIMD FPU exception support... done.
    [ 0.000000] Initializing CPU#0
    [ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
    [ 0.000000] Detected 2009.279 MHz processor.
    [ 24.709411] I-pipe 2.0-04: pipeline enabled.
    [ 24.709419] spurious 8259A interrupt: IRQ7.
    [ 24.712453] Console: colour VGA+ 80x25
    [ 24.712456] console [tty0] enabled
    [ 24.712836] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [ 24.713417] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [ 24.769379] Memory: 1937804k/1964928k available (1440k kernel code, 25736k reserved, 573k data, 228k init, 1047424k highmem)
    [ 24.769387] virtual kernel memory layout:
    [ 24.769388] fixmap : 0xfffed000 - 0xfffff000 ( 72 kB)
    [ 24.769389] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
    [ 24.769391] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
    [ 24.769392] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
    [ 24.769393] .init : 0xc02fa000 - 0xc0333000 ( 228 kB)
    [ 24.769394] .data : 0xc026836d - 0xc02f77ec ( 573 kB)
    [ 24.769396] .text : 0xc0100000 - 0xc026836d (1440 kB)
    [ 24.769399] Checking if this processor honours the WP bit even in supervisor mode... Ok.
    [ 24.769435] SLUB: Genslabs=11, HWalign=64, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
    [ 24.849358] Calibrating delay using timer specific routine.. 4020.32 BogoMIPS (lpj=8040644)
    [ 24.849381] Security Framework initialized
    [ 24.849386] SELinux: Disabled at boot.
    [ 24.849396] AppArmor: AppArmor initialized
    [ 24.849400] Failure registering capabilities with primary security module.
    [ 24.849406] Mount-cache hash table entries: 512
    [ 24.849495] CPU: After generic identify, caps: 078bfbff e3d3fbff 00000000 00000000 00000001 00000000 00000001 00000000
    [ 24.849502] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
    [ 24.849504] CPU: L2 Cache: 256K (64 bytes/line)
    [ 24.849506] CPU: After all inits, caps: 078bfbff e3d3fbff 00000000 00000410 00000001 00000000 00000001 00000000
    [ 24.849515] Compat vDSO mapped to ffffe000.
    [ 24.849523] CPU: AMD Sempron(tm) Processor 3400+ stepping 02
    [ 24.849527] Checking 'hlt' instruction... OK.
    [ 24.865457] Freeing SMP alternatives: 0k freed
    [ 24.865592] net_namespace: 64 bytes
    [ 24.865943] NET: Registered protocol family 16
    [ 24.866073] EISA bus registered
    [ 24.872634] PCI: PCI BIOS revision 3.00 entry at 0xfa7d0, last bus=4
    [ 24.872636] PCI: Using configuration type 1
    [ 24.872638] Setting up standard PCI resources
    [ 24.875464] Linux Plug and Play Support v0.97 (c) Adam Belay
    [ 24.875622] PCI: Probing PCI hardware
    [ 24.875628] PCI: Probing PCI hardware (bus 00)
    [ 24.876629] PCI: Transparent bridge - 0000:00:10.0
    [ 24.965294] AppArmor: AppArmor Filesystem Enabled
    [ 24.965551] PCI: Bridge: 0000:00:02.0
    [ 24.965553] IO window: a000-afff
    [ 24.965556] MEM window: fd700000-fd7fffff
    [ 24.965558] PREFETCH window: fde00000-fdefffff
    [ 24.965561] PCI: Bridge: 0000:00:03.0
    [ 24.965563] IO window: 9000-9fff
    [ 24.965565] MEM window: fdd00000-fddfffff
    [ 24.965568] PREFETCH window: fdc00000-fdcfffff
    [ 24.965570] PCI: Bridge: 0000:00:04.0
    [ 24.965572] IO window: b000-bfff
    [ 24.965575] MEM window: fd900000-fd9fffff
    [ 24.965577] PREFETCH window: fd800000-fd8fffff
    [ 24.965580] PCI: Bridge: 0000:00:10.0
    [ 24.965582] IO window: c000-cfff
    [ 24.965585] MEM window: fdb00000-fdbfffff
    [ 24.965588] PREFETCH window: fda00000-fdafffff
    [ 24.965598] PCI: Setting latency timer of device 0000:00:02.0 to 64
    [ 24.965604] PCI: Setting latency timer of device 0000:00:03.0 to 64
    [ 24.965610] PCI: Setting latency timer of device 0000:00:04.0 to 64
    [ 24.965618] PCI: Setting latency timer of device 0000:00:10.0 to 64
    [ 24.965626] NET: Registered protocol family 2
    [ 24.969215] Time: tsc clocksource has been installed.
    [ 25.001223] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    [ 25.001465] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    [ 25.002242] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
    [ 25.002440] TCP: Hash tables configured (established 131072 bind 65536)
    [ 25.002442] TCP reno registered
    [ 25.013288] checking if image is initramfs... it is
    [ 25.546081] Freeing initrd memory: 6867k freed
    [ 25.546414] audit: initializing netlink socket (disabled)
    [ 25.546424] audit(1213788845.780:1): initialized
    [ 25.546546] highmem bounce pool size: 64 pages
    [ 25.547774] VFS: Disk quotas dquot_6.5.1
    [ 25.547794] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [ 25.547882] io scheduler noop registered
    [ 25.547884] io scheduler anticipatory registered
    [ 25.547886] io scheduler deadline registered
    [ 25.547894] io scheduler cfq registered (default)
    [ 25.547908] Boot video device is 0000:00:05.0
    [ 33.558895] 0000:00:0b.1 EHCI: BIOS handoff failed (BIOS bug ?) 01010001
    [ 33.558988] PCI: Setting latency timer of device 0000:00:02.0 to 64
    [ 33.559009] assign_interrupt_mode Found MSI capability
    [ 33.559012] Allocate Port Service[0000:00:02.0cie00]
    [ 33.559059] PCI: Setting latency timer of device 0000:00:03.0 to 64
    [ 33.559079] assign_interrupt_mode Found MSI capability
    [ 33.559081] Allocate Port Service[0000:00:03.0cie00]
    [ 33.559125] PCI: Setting latency timer of device 0000:00:04.0 to 64
    [ 33.559145] assign_interrupt_mode Found MSI capability
    [ 33.559147] Allocate Port Service[0000:00:04.0cie00]
    [ 33.559258] isapnp: Scanning for PnP cards...
    [ 33.911811] isapnp: No Plug & Play device found
    [ 33.932994] Real Time Clock Driver v1.12ac
    [ 33.932997] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
    [ 33.933112] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
    [ 33.933823] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
    [ 33.933886] input: Macintosh mouse button emulation as /devices/virtual/input/input0
    [ 33.933976] PNP: No PS/2 controller found. Probing ports directly.
    [ 33.936435] serio: i8042 KBD port at 0x60,0x64 irq 1
    [ 33.936439] serio: i8042 AUX port at 0x60,0x64 irq 12
    [ 33.938630] mice: PS/2 mouse device common for all mice
    [ 33.938714] EISA: Probing bus 0 at eisa.0
    [ 33.938720] Cannot allocate resource for EISA slot 1
    [ 33.938740] EISA: Detected 0 cards.
    [ 33.938809] NET: Registered protocol family 1
    [ 33.938817] Using IPI Shortcut mode
    [ 33.938910] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
    [ 33.938912] EDD information not available.
    [ 33.939053] Freeing unused kernel memory: 228k freed
    [ 33.966421] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
    [ 35.161156] fuse init (API version 7.9)
    [ 35.508265] usbcore: registered new interface driver usbfs
    [ 35.508285] usbcore: registered new interface driver hub
    [ 35.514465] usbcore: registered new device driver usb
    [ 35.515131] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
    [ 35.515168] PCI: Setting latency timer of device 0000:00:0b.0 to 64
    [ 35.515171] ohci_hcd 0000:00:0b.0: OHCI Host Controller
    [ 35.515377] ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 1
    [ 35.515392] ohci_hcd 0000:00:0b.0: irq 10, io mem 0xfe02f000
    [ 35.555600] SCSI subsystem initialized
    [ 35.570593] usb usb1: configuration #1 chosen from 1 choice
    [ 35.570614] hub 1-0:1.0: USB hub found
    [ 35.570622] hub 1-0:1.0: 8 ports detected
    [ 35.588496] libata version 3.00 loaded.
    [ 35.672648] PCI: Setting latency timer of device 0000:00:0b.1 to 64
    [ 35.672652] ehci_hcd 0000:00:0b.1: EHCI Host Controller
    [ 35.672674] ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 2
    [ 35.672702] ehci_hcd 0000:00:0b.1: debug port 1
    [ 35.672706] PCI: cache line size of 64 is not supported by device 0000:00:0b.1
    [ 35.672714] ehci_hcd 0000:00:0b.1: irq 11, io mem 0xfe02e000
    [ 35.684362] ehci_hcd 0000:00:0b.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
    [ 35.684471] usb usb2: configuration #1 chosen from 1 choice
    [ 35.684489] hub 2-0:1.0: USB hub found
    [ 35.684495] hub 2-0:1.0: 8 ports detected
    [ 35.788422] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.61.
    [ 35.788440] PCI: Setting latency timer of device 0000:00:14.0 to 64
    [ 36.307993] forcedeth 0000:00:14.0: ifname eth0, PHY OUI 0x50ef @ 0, addr 00:40:ca:8f:b2:12
    [ 36.307998] forcedeth 0000:00:14.0: highdma pwrctl timirq lnktim desc-v3
    [ 36.310318] pata_amd 0000:00:0d.0: version 0.3.10
    [ 36.310364] PCI: Setting latency timer of device 0000:00:0d.0 to 64
    [ 36.311226] scsi0 : pata_amd
    [ 36.312143] scsi1 : pata_amd
    [ 36.312180] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf400 irq 14
    [ 36.312184] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf408 irq 15
    [ 36.327582] usb 1-5: new full speed USB device using ohci_hcd and address 2
    [ 36.484964] ata1.00: ATA-6: WDC WD1600BB-00GUC0, 08.02D08, max UDMA/100
    [ 36.484969] ata1.00: 312581808 sectors, multi 16: LBA48
    [ 36.485179] ata1.01: ATA-7: Maxtor 6Y160P0, YAR41BW0, max UDMA/133
    [ 36.485182] ata1.01: 320173056 sectors, multi 16: LBA48
    [ 36.495412] usb 1-5: configuration #1 chosen from 1 choice
    [ 36.501542] ata1.00: configured for UDMA/100
    [ 36.511450] usbcore: registered new interface driver libusual
    [ 36.515879] Initializing USB Mass Storage driver...
    [ 36.516334] ata1.01: configured for UDMA/133
    [ 36.517960] scsi2 : SCSI emulation for USB Mass Storage devices
    [ 36.518464] usbcore: registered new interface driver usb-storage
    [ 36.518469] USB Mass Storage support registered.
    [ 36.518550] usb-storage: device found at 2
    [ 36.518552] usb-storage: waiting for device to settle before scanning
    [ 36.883204] ata2.00: ATAPI: TSSTcorpCD/DVDW TS-H552D, GA01, max UDMA/33
    [ 36.883334] ata2.01: ATA-6: WDC WD800JB-00JJC0, 05.01C05, max UDMA/100
    [ 36.883337] ata2.01: 156301488 sectors, multi 16: LBA
    [ 37.094890] ata2.00: configured for UDMA/33
    [ 37.102984] ata2.01: configured for UDMA/100
    [ 37.103069] scsi 0:0:0:0: Direct-Access ATA WDC WD1600BB-00G 08.0 PQ: 0 ANSI: 5
    [ 37.103352] scsi 0:0:1:0: Direct-Access ATA Maxtor 6Y160P0 YAR4 PQ: 0 ANSI: 5
    [ 37.104468] scsi 1:0:0:0: CD-ROM TSSTcorp CD/DVDW TS-H552D GA01 PQ: 0 ANSI: 5
    [ 37.104667] scsi 1:0:1:0: Direct-Access ATA WDC WD800JB-00JJ 05.0 PQ: 0 ANSI: 5
    [ 37.109279] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
    [ 37.109284] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
    [ 37.109899] sata_nv 0000:00:0e.0: version 3.5
    [ 37.109950] PCI: Setting latency timer of device 0000:00:0e.0 to 64
    [ 37.110808] scsi3 : sata_nv
    [ 37.111302] scsi4 : sata_nv
    [ 37.111335] ata3: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xe000 irq 11
    [ 37.111338] ata4: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xe008 irq 11
    [ 37.115323] Driver 'sd' needs updating - please use bus_type methods
    [ 37.115395] sd 0:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
    [ 37.115406] sd 0:0:0:0: [sda] Write Protect is off
    [ 37.115409] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
    [ 37.115421] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [ 37.115457] sd 0:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
    [ 37.115463] sd 0:0:0:0: [sda] Write Protect is off
    [ 37.115466] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
    [ 37.115477] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [ 37.115480] sda:<4>Driver 'sr' needs updating - please use bus_type methods
    [ 37.134061] sda1 sda2
    [ 37.134123] sd 0:0:0:0: [sda] Attached SCSI disk
    [ 37.134174] sd 0:0:1:0: [sdb] 320173056 512-byte hardware sectors (163929 MB)
    [ 37.134183] sd 0:0:1:0: [sdb] Write Protect is off
    [ 37.134185] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
    [ 37.134197] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [ 37.134227] sd 0:0:1:0: [sdb] 320173056 512-byte hardware sectors (163929 MB)
    [ 37.134234] sd 0:0:1:0: [sdb] Write Protect is off
    [ 37.134236] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
    [ 37.134247] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [ 37.134251] sdb: sdb1 sdb2 < sdb5 >
    [ 37.149554] sd 0:0:1:0: [sdb] Attached SCSI disk
    [ 37.151307] sd 1:0:1:0: [sdc] 156301488 512-byte hardware sectors (80026 MB)
    [ 37.152217] sd 1:0:1:0: [sdc] Write Protect is off
    [ 37.152220] sd 1:0:1:0: [sdc] Mode Sense: 00 3a 00 00
    [ 37.154387] sd 1:0:1:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [ 37.161582] sr0: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
    [ 37.161585] Uniform CD-ROM driver Revision: 3.20
    [ 37.161619] sr 1:0:0:0: Attached scsi CD-ROM sr0
    [ 37.161625] sd 1:0:1:0: [sdc] 156301488 512-byte hardware sectors (80026 MB)
    [ 37.161634] sd 1:0:1:0: [sdc] Write Protect is off
    [ 37.161636] sd 1:0:1:0: [sdc] Mode Sense: 00 3a 00 00
    [ 37.161648] sd 1:0:1:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [ 37.161651] sdc: sdc1 sdc2 < sdc5 >
    [ 37.201544] sd 1:0:1:0: [sdc] Attached SCSI disk
    [ 37.205393] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [ 37.205410] sd 0:0:1:0: Attached scsi generic sg1 type 0
    [ 37.205424] sr 1:0:0:0: Attached scsi generic sg2 type 5
    [ 37.205441] sd 1:0:1:0: Attached scsi generic sg3 type 0
    [ 37.422264] ata3: SATA link down (SStatus 0 SControl 300)
    [ 37.636690] kjournald starting. Commit interval 5 seconds
    [ 37.636700] EXT3-fs: mounted filesystem with ordered data mode.
    [ 37.741878] ata4: SATA link down (SStatus 0 SControl 300)
    [ 41.521863] usb-storage: device scan complete
    [ 41.527172] scsi 2:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0
    [ 41.534038] scsi 2:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0
    [ 41.541034] scsi 2:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0
    [ 41.548024] scsi 2:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0
    [ 41.559776] sd 2:0:0:0: [sdd] Attached SCSI removable disk
    [ 41.559812] sd 2:0:0:0: Attached scsi generic sg4 type 0
    [ 41.570032] sd 2:0:0:1: [sde] Attached SCSI removable disk
    [ 41.570067] sd 2:0:0:1: Attached scsi generic sg5 type 0
    [ 41.581009] sd 2:0:0:2: [sdf] Attached SCSI removable disk
    [ 41.581042] sd 2:0:0:2: Attached scsi generic sg6 type 0
    [ 41.600277] sd 2:0:0:3: [sdg] Attached SCSI removable disk
    [ 41.601643] sd 2:0:0:3: Attached scsi generic sg7 type 0
    [ 42.457354] i2c-adapter i2c-0: nForce2 SMBus adapter at 0x1c00
    [ 42.457376] i2c-adapter i2c-1: nForce2 SMBus adapter at 0x1c40
    [ 42.832494] Linux video capture interface: v2.00
    [ 42.987831] saa7130/34: v4l2 driver version 0.2.14 loaded
    [ 43.007585] saa7130[0]: found at 0000:04:06.0, rev: 1, irq: 10, latency: 32, mmio: 0xfdbff000
    [ 43.007593] saa7130[0]: subsystem: 1461:10ff, board: AVerMedia DVD EZMaker [card=33,autodetected]
    [ 43.007609] saa7130[0]: board init: gpio is 10000
    [ 43.171346] saa7130[0]: i2c eeprom 00: 61 14 ff 10 ff ff ff ff ff ff ff ff ff ff ff ff
    [ 43.171354] saa7130[0]: i2c eeprom 10: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    [ 43.171361] saa7130[0]: i2c eeprom 20: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    [ 43.171367] saa7130[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    [ 43.171373] saa7130[0]: i2c eeprom 40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    [ 43.171378] saa7130[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    [ 43.171384] saa7130[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    [ 43.171390] saa7130[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    [ 43.171480] saa7130[0]: registered device video0 [v4l2]
    [ 43.171507] saa7130[0]: registered device vbi0
    [ 43.180251] saa7134 ALSA driver for DMA sound loaded
    [ 43.180277] saa7130[0]/alsa: saa7130[0] at 0xfdbff000 irq 10 registered as card -2
    [ 43.304781] PCI: Setting latency timer of device 0000:00:10.2 to 64
    [ 43.515291] input: PC Speaker as /devices/platform/pcspkr/input/input2
    [ 43.626853] intel8x0_measure_ac97_clock: measured 54883 usecs
    [ 43.626857] intel8x0: clocking to 46903
    [ 44.249647] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input3
    [ 45.401206] lp: driver loaded but no devices found
    [ 45.462235] Adding 3229024k swap on /dev/sdc5. Priority:-1 extents:1 across:3229024k
    [ 45.993778] EXT3 FS on sdc1, internal journal
    [ 47.077799] ip_tables: (C) 2000-2006 Netfilter Core Team
    [ 48.276733] ppdev: user-space parallel port driver
    [ 48.353682] audit(1213814069.101:2): type=1503 operation="inode_permission" requested_mask="a::" denied_mask="a::" name="/dev/tty" pid=4375 profile="/usr/sbin/cupsd" namespace="default"
    [ 49.440131] Bluetooth: Core ver 2.11
    [ 49.441795] NET: Registered protocol family 31
    [ 49.441799] Bluetooth: HCI device and connection manager initialized
    [ 49.441803] Bluetooth: HCI socket layer initialized
    [ 49.457387] Bluetooth: L2CAP ver 2.9
    [ 49.457391] Bluetooth: L2CAP socket layer initialized
    [ 49.475797] Bluetooth: RFCOMM socket layer initialized
    [ 49.475812] Bluetooth: RFCOMM TTY layer initialized
    [ 49.475814] Bluetooth: RFCOMM ver 1.8
    [ 53.544901] NET: Registered protocol family 17
    [ 56.571424] NET: Registered protocol family 10
    [ 56.571591] lo: Disabled Privacy Extensions
    [ 67.346277] eth0: no IPv6 routers present
    [ 132.122220] BUG: unable to handle kernel NULL pointer dereference at virtual address 00000038
    [ 132.122226] printing eip: f89b54d5 *pde = 00000000
    [ 132.122231] Oops: 0000 [#1]
    [ 132.122234] Modules linked in: ipv6 af_packet rfcomm l2cap bluetooth ppdev iptable_filter ip_tables x_tables lp parport psmouse serio_raw evdev pcspkr snd_intel8x0 snd_ac97_codec ac97_bus snd_pcm_oss snd_mixer_oss saa7134_alsa snd_pcm saa7134 compat_ioctl32 videobuf_dma_sg videobuf_core ir_kbd_i2c snd_seq_dummy ir_common videodev v4l2_common v4l1_compat snd_seq_oss snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq snd_timer snd_seq_device snd soundcore snd_page_alloc i2c_nforce2 i2c_core ext3 jbd mbcache sg sr_mod cdrom sd_mod amd74xx ide_core usb_storage libusual pata_amd sata_nv ata_generic forcedeth libata scsi_mod ehci_hcd ohci_hcd usbcore fuse
    [ 132.122263]
    [ 132.122265] Pid: 5088, comm: pulseaudio Not tainted (2.6.24-16-rtai #1)
    [ 132.122268] EIP: 0060:[] EFLAGS: 00010282 CPU: 0
    [ 132.122275] EIP is at snd_card_saa7134_capture_open+0xf/0x101 [saa7134_alsa]
    [ 132.122278] EAX: df9cd500 EBX: 00000000 ECX: df9e4678 EDX: f89b80ac
    [ 132.122281] ESI: df9cd500 EDI: df9e4000 EBP: 00000000 ESP: f75d1e64
    [ 132.122283] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
    [ 132.122286] Process pulseaudio (pid: 5088, ti=f75d0000 task=df931020 task.ti=f75d0000)<0>
    [ 132.122289] I-pipe domain Linux
    [ 132.122290] Stack: ffffffff df9e4000 00000000 f75d1eb0 df9ff200 f7fbf108 f89c6c25 f75d1e84
    [ 132.122295] df9cd500 f7fbf108 f7fbf000 f89c6cf9 f75d1eb0 00000001 00000000 df931020
    [ 132.122300] c010f197 f7fbf114 f7fbf114 df9ff200 f893c3e4 00000000 df9ff200 df8d51f4
    [ 132.122304] Call Trace:
    [ 132.122315] [] snd_pcm_open_substream+0x3c/0x76 [snd_pcm]
    [ 132.122334] [] snd_pcm_open+0x9a/0x172 [snd_pcm]
    [ 132.122351] [] default_wake_function+0x0/0x5
    [ 132.122368] [] snd_open+0xbb/0x105 [snd]
    [ 132.122386] [] chrdev_open+0xe0/0xf6
    [ 132.122397] [] chrdev_open+0x0/0xf6
    [ 132.122401] [] __dentry_open+0xc1/0x16d
    [ 132.122413] [] nameidata_to_filp+0x24/0x33
    [ 132.122421] [] do_filp_open+0x37/0x3e
    [ 132.122432] [] snd_ctl_release+0xbd/0xd9 [snd]
    [ 132.122460] [] get_unused_fd_flags+0x49/0xa8
    [ 132.122472] [] do_sys_open+0x44/0xca
    [ 132.122486] [] sys_open+0x1c/0x1e
    [ 132.122490] [] sysenter_past_esp+0x6e/0x72
    [ 132.122521] =======================
    [ 132.122522] Code: 78 42 00 8b 50 38 74 11 c7 82 54 05 00 00 01 00 00 00 89 d0 e8 d0 5a 02 00 31 c0 c3 55 57 56 89 c6 53 83 ec 08 8b 68 08 8b 78 70 <8b> 5d 38 8d 43 48 89 44 24 04 e8 59 f1 8a c7 8b 83 b8 05 00 00
    [ 132.122540] EIP: [] snd_card_saa7134_capture_open+0xf/0x101 [saa7134_alsa] SS:ESP 0068:f75d1e64
    [ 132.122548] ---[ end trace bed87f0925460442 ]---
    [ 199.291713] I-pipe: Domain RTAI registered.
    [ 199.291718] RTAI[hal]: <3.6> mounted over IPIPE-NOTHREADS 2.0-04.
    [ 199.291731] BUG: Unhandled exception over domain RTAI at 0xc013a453 - switching to ROOT
    [ 199.291736] Pid: 5241, comm: insmod Tainted: G D 2.6.24-16-rtai #1
    [ 199.291742] [] __ipipe_handle_exception+0x104/0x156
    [ 199.291751] [] __ipipe_restore_root+0xc/0x22
    [ 199.291767] [] error_code+0x6f/0x80
    [ 199.291789] [] __ipipe_restore_root+0xc/0x22
    [ 199.291795] [] release_console_sem+0x15f/0x1b1
    [ 199.291808] [] vprintk+0x239/0x261
    [ 199.291836] [] vsnprintf+0x29c/0x469
    [ 199.291854] [] printk+0x4c/0xb5
    [ 199.291866] [] rt_printk+0x3f/0x47 [rtai_hal]
    [ 199.291901] [] md5_transform+0x3ce/0x6df
    [ 199.291914] [] vt_console_print+0x0/0x249
    [ 199.291920] [] __call_console_drivers+0x34/0x40
    [ 199.291929] [] release_console_sem+0x198/0x1b1
    [ 199.291941] [] vprintk+0x255/0x261
    [ 199.291977] [] idr_get_new+0xa/0x24
    [ 199.291985] [] printk+0x4c/0xb5
    [ 199.291991] [] rtai_domain_entry+0x27/0x3f [rtai_hal]
    [ 199.292006] [] ipipe_register_domain+0x198/0x1cb
    [ 199.292016] [] __rtai_hal_init+0x1da/0x287 [rtai_hal]
    [ 199.292025] [] rtai_uvec_handler+0x0/0x3a [rtai_hal]
    [ 199.292038] [] sys_init_module+0x122e/0x13a6
    [ 199.292054] [] rtai_domain_entry+0x0/0x3f [rtai_hal]
    [ 199.292066] [] sys_init_module+0x12ee/0x13a6
    [ 199.292145] [] sysenter_past_esp+0x6e/0x72
    [ 199.292175] =======================
    [ 199.292182] ------------[ cut here ]------------
    [ 199.292184] Kernel BUG at c013a453 [verbose debug info unavailable]
    [ 199.292186] invalid opcode: 0000 [#2]
    [ 199.292188] Modules linked in: rtai_hal ipv6 af_packet rfcomm l2cap bluetooth ppdev iptable_filter ip_tables x_tables lp parport psmouse serio_raw evdev pcspkr snd_intel8x0 snd_ac97_codec ac97_bus snd_pcm_oss snd_mixer_oss saa7134_alsa snd_pcm saa7134 compat_ioctl32 videobuf_dma_sg videobuf_core ir_kbd_i2c snd_seq_dummy ir_common videodev v4l2_common v4l1_compat snd_seq_oss snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq snd_timer snd_seq_device snd soundcore snd_page_alloc i2c_nforce2 i2c_core ext3 jbd mbcache sg sr_mod cdrom sd_mod amd74xx ide_core usb_storage libusual pata_amd sata_nv ata_generic forcedeth libata scsi_mod ehci_hcd ohci_hcd usbcore fuse
    [ 199.292213]
    [ 199.292215] Pid: 5241, comm: insmod Tainted: G D (2.6.24-16-rtai #1)
    [ 199.292218] EIP: 0060:[] EFLAGS: 00010202 CPU: 0
    [ 199.292221] EIP is at __ipipe_restore_root+0xc/0x22
    [ 199.292223] EAX: 00000001 EBX: 00005ee8 ECX: ffffffff EDX: 00005f2d
    [ 199.292225] ESI: 00005f2d EDI: 00005f2d EBP: 00005f2d ESP: f7743cac
    [ 199.292228] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
    [ 199.292230] Process insmod (pid: 5241, ti=f7742000 task=f777c560 task.ti=f7742000)<0>
    [ 199.292232] I-pipe domain Linux
    [ 199.292233] Stack: c0112967 00000000 fffff3ad f7743d08 00000200 00000012 f7743d08 c0112d33
    [ 199.292238] f7743cf6 c02a1d48 00000036 000000c7 00047386 00f585e0 00000048 c033dcd1
    [ 199.292242] 66b64bc9 116345c9 363cffce 20205b3e 2e393931 37313932 205d3831 00047300
    [ 199.292245] Call Trace:
    [ 199.292247] [] release_console_sem+0x15f/0x1b1
    [ 199.292259] [] vprintk+0x239/0x261
    [ 199.292287] [] vsnprintf+0x29c/0x469
    [ 199.292303] [] printk+0x4c/0xb5
    [ 199.292315] [] rt_printk+0x3f/0x47 [rtai_hal]
    [ 199.292347] [] md5_transform+0x3ce/0x6df
    [ 199.292359] [] vt_console_print+0x0/0x249
    [ 199.292364] [] __call_console_drivers+0x34/0x40
    [ 199.292372] [] release_console_sem+0x198/0x1b1
    [ 199.292384] [] vprintk+0x255/0x261
    [ 199.292418] [] idr_get_new+0xa/0x24
    [ 199.292427] [] printk+0x4c/0xb5
    [ 199.292432] [] rtai_domain_entry+0x27/0x3f [rtai_hal]
    [ 199.292447] [] ipipe_register_domain+0x198/0x1cb
    [ 199.292458] [] __rtai_hal_init+0x1da/0x287 [rtai_hal]
    [ 199.292466] [] rtai_uvec_handler+0x0/0x3a [rtai_hal]
    [ 199.292479] [] sys_init_module+0x122e/0x13a6
    [ 199.292496] [] rtai_domain_entry+0x0/0x3f [rtai_hal]
    [ 199.292507] [] sys_init_module+0x12ee/0x13a6
    [ 199.292589] [] sysenter_past_esp+0x6e/0x72
    [ 199.292618] =======================
    [ 199.292619] Code: 0b eb fe fa 0f ba 35 a4 14 2e c0 00 83 3d a8 14 2e c0 00 74 08 83 c8 ff e8 f4 fb ff ff fb c3 81 3d 24 19 2e c0 80 31 38 c0 74 04 <0f> 0b eb fe 85 c0 74 09 0f ba 2d a4 14 2e c0 00 c3 e9 b2 ff ff
    [ 199.292635] EIP: [] __ipipe_restore_root+0xc/0x22 SS:ESP 0068:f7743cac
    [ 199.292640] ---[ end trace bed87f0925460442 ]---
    Debug file information:
    /etc/init.d/realtime: line 148: 5241 Segmentation fault $INSMOD $MOD
    5226
    PID TTY STAT TIME COMMAND
    Stopping realtime threads
    RTAPI: ERROR: could not open shared memory (errno=2)
    HAL: ERROR: rtapi init failed
    halcmd: hal_init() failed: -9
    NOTE: 'rtapi' kernel module must be loaded
    Unloading hal components
    ERROR: Module hal_lib does not exist in /proc/modules
    ERROR: Module rtapi does not exist in /proc/modules
    ERROR: Module rtai_math does not exist in /proc/modules
    ERROR: Module rtai_sem does not exist in /proc/modules
    ERROR: Module rtai_fifos does not exist in /proc/modules
    ERROR: Module rtai_sched does not exist in /proc/modules
    ERROR: Module rtai_hal is in use
    Jun 2008
    Default Update
    I tried the run from CD option, with the same results.
    Then I tried it on a Dell Vostro 400 and it worked just fine. EMC2 seems to do exactly what I need.
    So I know the Disk ISO burned well.
    Still no clue about the RTAPI error on the other machine. Maybe it has something to do with the nVidia card? Both have a full complement of RAM and are running XP Home.
    Thanks again to those that have looked at this thread.
    Feb 2007
    While I don't know what gives you the error there is some good info on this page
    http://wiki.linuxcnc.org/cgi-bin/emc...roubleShooting
    John
    Jun 2008
    Thanks John.
    I've tried to fight through that page, but am still swimming in too deep water understanding what it all means.
    In a bid to work around this problem I've been looking at the Linux powered Everex gPC2 TC2512 Desktop at Walmart.
    According to the reviews, many people seem to have easily installed Ubuntu on it.
    Has anyone used it or see any reason why it would be unsuitable for a EMC2 machine? For $200 it seems quite a deal.
    Kind Regards
    David
    May 2005
    canada
    One problem with that WalMart machine will be the integrated graphics. Can a graphics card be added? From the spec sheet it looks like the answer is no, but I may be reading incorrectly.
    "real time system failed to load.". Not sure what would cause this. I've also had hard luck with an emc install. On that particular machine no amount of messing in the bios solved the problem. However in that case the problem was seemingly random latency errors.
    Maybe a good wiki contribution would be a build sheet. Something like;
    "Go to NewEgg and buy exactly these components, use exactly these bios settings, and exceptional realtime performance is guaranteed."
    Random thought: Linuxcnc.org could sell computers ready to roll. This has probably been considered and rejected for good reason.
    Anyone who says "It only goes together one way" has no imagination.
    Feb 2007
    Just another thought, I had one computer with windows and the live CD would not work (I forget the exact reason) I took out the hard drive with windoz and put an blank hard drive in and danged if it didn't work and is running my plasma cutter to this day...
    At this point I'm positive that I don't know about all the things I don't know anything about when it comes to Linux...
    John
  7. #7
    Jun 2008
    As a Linux newb who likes to start using, then learn alongside the user experience, a list of tested hardware and setups would make life so much easier. Hence the search for a reasonably priced off the shelf box - but WHICH one?
    I believe you are right about the video: This link shows no video slots.
    I have an optimistic (probably unfounded) hope that as it is sold as a Linux machine and people have run Ubuntu on it that the manufacturer at least knew that linux compatible video would be a factor.
    Is it at all safe to assume that if Ubuntu works well, then EMC2 would too?
    Maybe I can try it and then return it if the live EMC2/Ubuntu CD doesn't function well...
    Though John's reply seems to indicate that all is not always logical when Linux and compatibility is concerned.
    Quote Originally Posted by cyclestart View Post
  8. #8
    Feb 2007
    Quote Originally Posted by oakes3 View Post
    And it could have been the Windoz causing the problems... So take your live CD down to WallyWorld and boot up the computer you want and check the latency... What can they say...
    John
  9. #9
    Jun 2008
    united states
    Hey oakes3
    I think your problem is that you do not have Ubuntu booting from the real time kernel. What you need to do is install grub editor and edit your grub so that the real time kernel loads by default. I have installed EMC2 on Ubuntu Ultimate 1.8 and had the same issue when I updated and updates installed a newer kernel. I had to edit the grub and revert back to the real time kernel. Good luck.
  10. #10
    Gold Member acondit's Avatar
    Apr 2005
    The problem with some onboard video controllers is that they have too much latency to work well with the real time needs of EMC2, not that they don't work well with linux.
    NO. It must work well with both Ubuntu and the real time kernel.
    I don't know the answer to this question, but I would suggest asking the seller that question. There has been discussion of certain motherboards that have on board video controllers that do work well with EMC2. I have this one bookmarked. I don't own one so I can't personally vouch for it.
    Alan
  11. #11
    May 2005
    canada
    Quote Originally Posted by acondit View Post
    Yes, sorry for not stating that more clearly. If the onboard video turns out to be a problem, what? No AGP or PCIE slot. Would a regular pci graphics card work? I'm not a hardware guru by any stretch.
    Maybe the UniChrome onboard would work. Depends on the motherboard probably?
    http://wiki.linuxcnc.org/cgi-bin/emc...l?Latency-Test
    I'd just hate to see you buy a unit specifically for emc2 and be disappointed
    I'm still curious why the realtime modules fail to load. According to the first line of the kernel messages you are running the realtime kernel. Or at least that's how I read it. Will check my dmesg later to compare if no one responds earlier.
  12. #12
    May 2005
    canada
    Here's the output on my 8.0.4 booting a realtime kernel.
    "uname -r" reports this
    2.6.24-16-rtai
    However this machine is setup for simulation only and normally boots 2.6.24-19-generic.
    Did you try the emc2-install.sh script? The result would be the same as using the emc distributed cd afaik, which apparently fails in the same way. Weird. Something about your install feels wrong. Can't be more specific for now.
    Jeff
    messing up an install for the entertainment of others
