How run pluto step on emc2 ?
Results 1 to 4 of 4
Thread: How run pluto step on emc2 ?
    Jun 2007
    France
    Question How run pluto step on emc2 ?
    I don't understand which is the procedure to install pluto-step in emc2. The examples of emc2 with pluto-servo functions, but I want to use pluto-step. And I don't understand the procedure to include pluto-step in emc2.
    Can somebody explain me the procedure?
    Thanks,
    Stephane
    Jul 2003
    Holmen, WI
    if you look in the configs/stepper/ there is a pluto ini and hal file.
    http://cvs.linuxcnc.org/cgi-bin/cvsw...nfigs/stepper/
    sam
    Jul 2003
    Holmen, WI
    and
    http://www.linuxcnc.org/docs/2.2/htm...to_step.9.html
    make sure to take note of 'speedrange' you need to set it for what range will work with your machine. The limited space in the pluto required this trade-off
    you can read a bit about the history of it here
    http://axis.unpythonic.net/01183862490
    http://axis.unpythonic.net/01185276001
    sam
    Jun 2007
    France
    Talking
    Thank you very much sam !
    I am a newbie with emc2. And it's not very easy at the beginning...
    Yes, I read the limitations of the pluto-step. But I think that must go with my machine.
    Thanks again
