Newbie Linux CNC, what controller / breakout board is most flexible?
Results 1 to 1 of 1
Thread: Linux CNC, what controller / breakout board is most flexible?
    Dec 2014
    Default Linux CNC, what controller / breakout board is most flexible?
    Hi!
    I'm considering Linux CNC over Centroid OAK for my VMC retrofit/upgrade.
    I need several inputs (tool changer and I want hardkeys for most common functions), and some outputs for PLC functions.
    I wonder what MESA (?) board combo to use, that gives me most flexibility?
    Would it be smart to use one "bigger" board in the control cabinet, and a "smaller" one in the control stand panel to connect all buttons and indicators?
    Can all units, PC, control board, "slave board" be connected via ethernet?
    Br, Magnar.
    Attached Thumbnails Attached Thumbnails Linux CNC, what controller / breakout board is most flexible?-20210310_142822-jpg
    taniyuki's Avatar
    Aug 2023
    Default Re: Linux CNC, what controller / breakout board is most flexible?
    What is the best control setup for a DIY table? Im looking at the warp9 with 3in1 THC but im not sure if that is the way to go. im sure this topic has been beaten to death before so i apologies for the repeat question
    tiny fishing
    sarahcarter's Avatar
    Mar 2024
    Searching for the best services is good and we can get what we want. Also, from the BG Electrical & Air Con I come to know about the best services are we are in need of.
