Starting to install Linuxcnc for a Mill that is using a MESA 7i92h and PMDX126. This same mill was using MACH3, the pmdx126 and a smoothstepper.
I have flashed the 7i92 with 7i92_PMDX126x2D.bit.
I began by using PNCCONF to create a configuration. Was able to select the mesa board, but in the firmware section there was no entry for a pmdx126. After a quick setup I have gotten the X, Y and Z axis moving in Linuxcnc. I need to configure my probe and home switch inputs, as well as my spindle. Couple questions.
1) Is there a way to add the PMDX126 firmware as a selection for the 7i92 in pncconf?
2) Does anyone have an example .hal file for the 7i92 and the PMDX126?
Thanks,
Scott...
Instructional Videos for CNC Guitar Building
http://www.rmgvideos.com
