gcode and gmoccapy
Results 1 to 5 of 5
Thread: gcode and gmoccapy
    Member Fiury's Avatar
    Jan 2021
    Lightbulb gcode and gmoccapy
    Hello ,
    can someone look , why is not running ?
    EMC2 , gmoccapy
    CAD, CAM fusion360 hobby
    It is first try to run gcode.
    Homemade mill, all things running thru touchpanel (only cooling is running still not by touching cool)
    Thank you
    Fiury
    Attached Thumbnails Attached Thumbnails gcode and gmoccapy-img_7206-jpg
    Attached Files Attached Files
    Community Moderator wendtmk's Avatar
    Dec 2005
    Default Re: gcode and gmoccapy
    What is the text in the box at the bottom of the screen with a red X say? It's too small to see what is there. Any other errors pop up when you attempt to run the G code file?
    Mark
    Jan 2021
    No popup and red is M3 in : N30 S10000 M3
    If you mean textbox on mouseover, ther is run the program, because mouse in over play button.
    It looks like paused because of something..
    Member routalot's Avatar
    Dec 2003
    The screen shows the intended tool trajectory so I would ask two things;did the operation run without problems when simulated in Fusion?Second,did you choose and configure the post processor correctly?I can't offer too much help because I use Freecad and the interface on my machine is the standard Axis version of LinuxCNC.
    I have a strong suspicion that the line causing the trouble is N25 T3 M6.If you don't have an ATC (and most of us don't) the machine won't know how to handle this command.I suggest you delete this line and try running the sequence WITH NO TOOL INSTALLED AND NO MATERIAL ON THE BED OF THE MACHINE. If it runs as intended,you would then be able to do it for real.
    Dec 2003
    Well?
gcode and gmoccapy
gcode and gmoccapy
