Hi All
I have a problem getting my machine to work with MESA 7i96 and Stepper driver TB6600.i tried changing the step/dir timing with no success. i lowered the velocity and acceleration to 400mm/min, Ii still get the following error with joint xx[/u].
Hardware:
- MESA 7i96
-TB6600 + NEMA23
Software:
-LinuxCNC version 2.8.1
-4.9.0-8-rt-686-pae
LinuxCNC output
Code:
LINUXCNC - 2.8.1
Machine configuration directory is '/home/taz/linuxcnc/configs/workBee_Base'
Machine configuration file is 'workBee_Base.ini'
INIFILE=/home/taz/linuxcnc/configs/workBee_Base/workBee_Base.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYYZ
KINEMATICS=trivkins coordinates=XYYZ kinstype=BOTH
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./workBee_Base.hal
Found file(REL): ./custom.hal
Starting TASK program: milltask
Starting DISPLAY program: axis
62914563
joint 0 following error
emc/task/taskintf.cc 942: Error on joint 0, command number 5063
here are my config files:
Code:
# Generated by PNCconf at Sun May 9 17:06:17 2021
# Using LinuxCNC version: 2.8
# If you make changes to this file, they will be
# overwritten when you run PNCconf again
[EMC]
MACHINE = workBee_Base
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EMBED_TAB_NAME = GladeVCP
EMBED_TAB_COMMAND = halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -H gvcp_call_list.hal -x {XID} gvcp-panel.ui
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/taz/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 8.333333
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
# **** This is for info only ****
CARD0=hm2_7i96.0
[HAL]
HALUI = halui
HALFILE = workBee_Base.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
MDI_COMMAND = G10 L20 P0 X0 ( Set X to zero )
MDI_COMMAND = G10 L20 P0 Y0 ( Set Y to zero )
MDI_COMMAND = G10 L20 P0 Z0 ( Set Z to zero )
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
[TRAJ]
COORDINATES = XYYZ
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 2.00
MAX_LINEAR_VELOCITY = 20.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOL_CHANGE_QUILL_UP = 1
[AXIS_X]
MAX_VELOCITY = 16.6666666667
MAX_ACCELERATION = 10.0
MIN_LIMIT = -200.0
MAX_LIMIT = 300.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 2.0
# The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION
# If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger.
STEPGEN_MAXVEL = 20.83
STEPGEN_MAXACCEL = 12.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 10000
DIRHOLD = 1500
STEPLEN = 7000
STEPSPACE = 500
STEP_SCALE = 200.0
MIN_LIMIT = -200.0
MAX_LIMIT = 300.0
HOME_OFFSET = 0.0
[AXIS_Y]
MAX_VELOCITY = 20.0
MAX_ACCELERATION = 12.0
MIN_LIMIT = -400.0
MAX_LIMIT = 500.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 2.0
MAX_VELOCITY = 20.0
STEPGEN_MAXVEL = 25.00
STEPGEN_MAXACCEL = 15.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 1000
STEPLEN = 5000
STEPSPACE = 500
STEP_SCALE = 200.0
MIN_LIMIT = -400.0
MAX_LIMIT = 500.0
HOME_OFFSET = 0.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 2.0
MAX_VELOCITY = 20.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 1000
STEPLEN = 5000
STEPSPACE = 500
STEP_SCALE = 200.0
MIN_LIMIT = -400.0
MAX_LIMIT = 500.0
HOME_OFFSET = 0.0
[AXIS_Z]
MAX_VELOCITY = 13.3333333333
MIN_LIMIT = -30.0
MAX_LIMIT = 30.0
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 2.0
STEPGEN_MAXVEL = 16.67
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 1500
STEPLEN = 7000
STEPSPACE = 500
STEP_SCALE = 200.0
MIN_LIMIT = -30.0
MAX_LIMIT = 30.0
HOME_OFFSET = 0.0
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 2000.0
Code:
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp hm2_7i96.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.y2,pid.z,pid.s
addf hm2_7i96.0.read servo-thread
addf motion-command-handler servo-thread
addf motion-controller servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.y2.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i96.0.write servo-thread
# external output signals
# --- MACHINE-IS-ENABLED ---
net machine-is-enabled => hm2_7i96.0.ssr.00.out-02
# --- DOUT-00 ---
net dout-00 => hm2_7i96.0.ssr.00.out-03
# --- SPINDLE-ENABLE ---
net spindle-enable => hm2_7i96.0.ssr.00.out-04
# external input signals
# --- PROBE-IN ---
net probe-in <= hm2_7i96.0.gpio.010.in
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.012700
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp hm2_7i96.0.stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp hm2_7i96.0.stepgen.00.dirhold [JOINT_0]DIRHOLD
setp hm2_7i96.0.stepgen.00.steplen [JOINT_0]STEPLEN
setp hm2_7i96.0.stepgen.00.stepspace [JOINT_0]STEPSPACE
setp hm2_7i96.0.stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp hm2_7i96.0.stepgen.00.step_type 0
setp hm2_7i96.0.stepgen.00.control-type 1
setp hm2_7i96.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_7i96.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output <= hm2_7i96.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i96.0.stepgen.00.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => hm2_7i96.0.stepgen.00.enable
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# AXIS Y JOINT 1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror 0.012700
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output <= pid.y.output
setp hm2_7i96.0.stepgen.03.dirsetup [JOINT_1]DIRSETUP
setp hm2_7i96.0.stepgen.03.dirhold [JOINT_1]DIRHOLD
setp hm2_7i96.0.stepgen.03.steplen [JOINT_1]STEPLEN
setp hm2_7i96.0.stepgen.03.stepspace [JOINT_1]STEPSPACE
setp hm2_7i96.0.stepgen.03.position-scale [JOINT_1]STEP_SCALE
setp hm2_7i96.0.stepgen.03.step_type 0
setp hm2_7i96.0.stepgen.03.control-type 1
setp hm2_7i96.0.stepgen.03.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_7i96.0.stepgen.03.maxvel [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd <= joint.1.motor-pos-cmd
net y-vel-cmd <= joint.1.vel-cmd
net y-output <= hm2_7i96.0.stepgen.03.velocity-cmd
net y-pos-fb <= hm2_7i96.0.stepgen.03.position-fb
net y-pos-fb => joint.1.motor-pos-fb
net y-enable <= joint.1.amp-enable-out
net y-enable => hm2_7i96.0.stepgen.03.enable
net y-home-sw => joint.1.home-sw-in
net y-neg-limit => joint.1.neg-lim-sw-in
net y-pos-limit => joint.1.pos-lim-sw-in
# Tandem AXIS Y2 JOINT 2
setp pid.y2.Pgain [JOINT_2]P
setp pid.y2.Igain [JOINT_2]I
setp pid.y2.Dgain [JOINT_2]D
setp pid.y2.bias [JOINT_2]BIAS
setp pid.y2.FF0 [JOINT_2]FF0
setp pid.y2.FF1 [JOINT_2]FF1
setp pid.y2.FF2 [JOINT_2]FF2
setp pid.y2.deadband [JOINT_2]DEADBAND
setp pid.y2.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.y2.error-previous-target true
setp pid.y2.maxerror 0.012700
net y2-index-enable <=> pid.y2.index-enable
net y2-enable => pid.y2.enable
net y2-pos-cmd => pid.y2.command
net y2-pos-fb => pid.y2.feedback
net y2-output <= pid.y2.output
# Step Gen signals/setup for tandem axis
setp hm2_7i96.0.stepgen.02.dirsetup [JOINT_2]DIRSETUP
setp hm2_7i96.0.stepgen.02.dirhold [JOINT_2]DIRHOLD
setp hm2_7i96.0.stepgen.02.steplen [JOINT_2]STEPLEN
setp hm2_7i96.0.stepgen.02.stepspace [JOINT_2]STEPSPACE
setp hm2_7i96.0.stepgen.02.position-scale [JOINT_2]STEP_SCALE
setp hm2_7i96.0.stepgen.02.step_type 0
setp hm2_7i96.0.stepgen.02.control-type 1
setp hm2_7i96.0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_7i96.0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL
net y2-pos-cmd <= joint.2.motor-pos-cmd
net y2-vel-cmd <= joint.2.vel-cmd
net y2-output <= hm2_7i96.0.stepgen.02.velocity-cmd
net y2-pos-fb <= hm2_7i96.0.stepgen.02.position-fb
net y2-pos-fb => joint.2.motor-pos-fb
net y2-enable <= joint.2.amp-enable-out
net y2-enable => hm2_7i96.0.stepgen.02.enable
net y2-home-sw => joint.2.home-sw-in
net y2-neg-limit => joint.2.neg-lim-sw-in
net y2-pos-limit => joint.2.pos-lim-sw-in
# AXIS Z JOINT 3
setp pid.z.Pgain [JOINT_3]P
setp pid.z.Igain [JOINT_3]I
setp pid.z.Dgain [JOINT_3]D
setp pid.z.bias [JOINT_3]BIAS
setp pid.z.FF0 [JOINT_3]FF0
setp pid.z.FF1 [JOINT_3]FF1
setp pid.z.FF2 [JOINT_3]FF2
setp pid.z.deadband [JOINT_3]DEADBAND
setp pid.z.maxoutput [JOINT_3]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror 0.012700
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp hm2_7i96.0.stepgen.01.dirsetup [JOINT_3]DIRSETUP
setp hm2_7i96.0.stepgen.01.dirhold [JOINT_3]DIRHOLD
setp hm2_7i96.0.stepgen.01.steplen [JOINT_3]STEPLEN
setp hm2_7i96.0.stepgen.01.stepspace [JOINT_3]STEPSPACE
setp hm2_7i96.0.stepgen.01.position-scale [JOINT_3]STEP_SCALE
setp hm2_7i96.0.stepgen.01.step_type 0
setp hm2_7i96.0.stepgen.01.control-type 1
setp hm2_7i96.0.stepgen.01.maxaccel [JOINT_3]STEPGEN_MAXACCEL
setp hm2_7i96.0.stepgen.01.maxvel [JOINT_3]STEPGEN_MAXVEL
setp hm2_7i96.0.stepgen.01.direction.invert_output true
net z-pos-cmd <= joint.3.motor-pos-cmd
net z-vel-cmd <= joint.3.vel-cmd
net z-output <= hm2_7i96.0.stepgen.01.velocity-cmd
net z-pos-fb <= hm2_7i96.0.stepgen.01.position-fb
net z-pos-fb => joint.3.motor-pos-fb
net z-enable <= joint.3.amp-enable-out
net z-enable => hm2_7i96.0.stepgen.01.enable
net z-home-sw => joint.3.home-sw-in
net z-neg-limit => joint.3.neg-lim-sw-in
net z-pos-limit => joint.3.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
# ---setup spindle control signals---
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-at-speed => spindle.0.at-speed
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
# ---Setup spindle at speed signals---
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
net dout-00 <= motion.digital-out-00
# ---estop signals---
net estop-out <= iocontrol.0.user-enable-out
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
loadusr -W hal_manualtoolchange
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
T
