LinuxCNC 2.8.0 is released
Results 1 to 3 of 3
Thread: LinuxCNC 2.8.0 is released
    Sep 2008
    UK
    Default LinuxCNC 2.8.0 is released
    I am pleased (and a little relieved) to announce the release of LinuxCNC v2.8.0
    This release has been a long time in development. The main new
    feature, the separation of joints (actuators) and (cartesian) axes has
    been in development since around 2010.
    This is one of the biggest updates to LinuxCNC ever. The changelog can
    be viewed here:
    https://github.com/LinuxCNC/linuxcnc...bian/changelog
    Highlights include:
    * Joints-axes separation - mainly obvious as much better support for
    gantries and their homing but also for robots and any other
    non-cartesian system
    * Reverse-run - negative feed-overide will now reverse along the
    previous path - introduced for wire spark eroders, but I am sure you
    will find other uses.
    * Multiple spindle support - up to 9 spindles
    * Tool table expanded to 1000 tools
    * Packages available for Raspberry Pi 4.
    * External offsets - G-code is not the only way to move things.
    * QTvcp: New QT-based VCP framework
    * QTdragon, QTlathe, QTtouchy, QTscreen - new GUIs based on QTVP
    * Silverdragon: New gscreen based GUI
    * plasmac: New full-featured Plasma cutter controller - with
    integrated THC and a whole lot more.
    * Massively expanded and improved Spanish translations of
    documentation and manpages
    * New Chinese translation of the "??" (Getting Started) documentation.
    Installable packages are available for Ubuntu Precise and Debians
    Wheezy, Stretch, Jessie and Buster (including Raspbian). Support for
    Ubuntu Lucid has ended.
    At the moment most supported platforms only work with the preempt-rt kernels.
    There is an experimental 64-bit RTAI kernel for those needing it. We
    hope to mainline this soon, but help would be appreciated.
    More details of how to update here:
    Updating LinuxCNC
    For new installations, or to test-run the new version and OS on your
    existing hardware without committing to an OS upgrade use the ISO
    images and process described here:
    Getting LinuxCNC
    Many thanks to the following contributors, and to anyone else who has
    submitted work or code to the project.
    Alec Ari
    Alexander Brock
    Alex Joni
    Alex Wigen
    Al Smart
    Andrea Ricchi
    Andrew Kyrychenko
    andypugh
    Anthony Barney
    Anton Midyukov
    ascurtis
    Balestrino
    bebro
    Bence Kovacs
    Benjamin Brockhaus
    Benjamin Weis
    Bernhard M. Wiedemann
    Bertho Stultiens
    blazini36
    Boris Skegin
    Brian Hicks
    cascade256
    Chris Edwards
    Chris Morley
    Chris Radek
    Colten Edwards
    Curtis Dutton
    Daniel Rogge
    david
    David Shore
    Dewey Garrett
    Eduard Kachur
    Edward Tomasz Napierala
    Ernesto Lo Valvo
    Florian Kerle
    Gergely Nagymate
    Hannah Lau
    Håvard Flaget Aasen
    itai
    itaib
    James Waples
    Jan Mrázek
    jasen
    Jeff Epler
    Jim Craig
    Jin
    j.m. garcia
    Joe Hildreth
    John
    John Kasunich
    John Morris
    John Thornton
    Jon Elson
    Kim Kirwan
    Kurt Jacobson
    Lars Bensmann
    Les Newell
    loopsun
    Lorenz Neureuter
    Lubomir Rintel
    Luke Peterson
    Mark Andrew Gerads
    Markus
    Mateusz Konieczny
    Matsche
    Michael Geszkiewicz
    Michael Haberler
    Mick
    Moses McKnight
    MrFouFou
    Nicola Quargentan
    Norbert Schechner
    Oleg Pryadko
    peter wallace
    Phillip A Carter
    Phillip Carter
    pippin88
    Rene Hopf
    Rick M
    Robert W. Ellenberg
    rolf
    Rudy du Preez
    Ruoxi Wang
    Rushabh Loladia
    sam sokolik
    Sam Sokolik
    Sebastian Kuzminsky
    Sergey Alirzaev
    Solitarily
    sphasse
    Stephen Wille Padnos
    Sync
    Tero Kaarlela
    Thomas Burkhard
    Tom Schneider
    Tr?n Ng?c Quân
    tseufl
    TurBoss
    Will Glynn
    May 2015
    Default Re: LinuxCNC 2.8.0 is released
    Great work Andy. You did a great job as release manager!
    Rod Webster
    www.vmn.com.au
    Mar 2021
    Quote Originally Posted by Hison View Post
    I didn't like these translations, the grammar is badly distorted.
    What's the best way to translate it?
