Problem G76 issue
Results 1 to 2 of 2
Thread: G76 issue
    Feb 2006
    Default G76 issue
    I am threading an 8-acme inside thread, I set the Q to 14, however the cut angle is much greater than that. probably closer to 20 or even as much as 25 degrees. when I cut a 60 degree thread and set the compound angle Q to 30 it works fine. has anyone else had this issue and may have a fix for it?
    this is the code:
    G76 P0.125 Z-3.0 I0.100 J0.008 K0.170 Q14 R1.5
    I plan on trying a Q7, but even if that works I would still like to understand the problem.
    thanks for your help.
    Ray,
    Life is a choice, death is choice poorly made.
    May 2008
    uk
    Default Re: G76 issue
    I'm not running LinuxCNC myself, I'm using PlanetCNC which claims compatability with LinuxCNC.
    I copied & pasted your code into my controller and it looked good.
    Picture attached.
    Martin.
    G76 issue-ice_screenshot_20200308-105802-jpg
G76 issue
G76 issue
