LINUXCNC weird program issue
Results 1 to 2 of 2
Thread: LINUXCNC weird program issue
    Member logan224's Avatar
    Nov 2019
    Default LINUXCNC weird program issue
    I am trying to run a program and when it calls up tool 12 it doesn't seem to do what it's supposed to. The preview on Linuxcnc shows the tool in one spot but the tool is actually in a different spot. i do not have this problem with any other tool paths in the program. When I separate the toolpath into its own program it goes to a different location. The code between the to programs is the same I dont understand why it is doing this any help would be appreciated.
    Attached Files Attached Files
    Mar 2007
    U.S.A.
    Default Re: LINUXCNC weird program issue
    Did you get this figured out?
