Problem how to change time and date
Results 1 to 5 of 5
Thread: how to change time and date
    Aug 2011
    kansas
    Default how to change time and date
    Community Moderator wendtmk's Avatar
    Dec 2005
    Default Re: how to change time and date
    You can do it from either the command line or the GUI. For the command line either man date or man rdate. The GUI should be self explanatory. What version of Linux are you running?
    Mark
    Aug 2011
    kansas
    hi,i believe the version is 4.8.6.I did try the command line but did not success, because i am new to linux.can you let me know where can i change the date and time from the GUI.thks.
    Dec 2005
    Look under the "System Settings" for "Date and Time."
    You probably need to use 'sudo' to use date or rdate from the command line to change the date and time. Type "man sudo" for an understanding on how sudo elevates your privileges on the system to enable system changes.
    Mark
    Aug 2011
    kansas
    hi mark,i will give it a try,thks.
