Curving between corners
Results 1 to 3 of 3
Thread: Curving between corners
    Dec 2014
    Default Curving between corners
    I'm having an issue where corners are being rounded when there is no compensation or curves set in the GCode file, in fact the file specifically contains a G40 and G49 at the beginning to cancel any compensatory moves.
    I've used the same GCode files before on my old install so I'm assuming it's either a wrongly configured setting or something new in LinuxCNC since my old install (2.6.4). This is the first time I've used these files since my upgrade (I changed my controller to a GeckoDrive from a cheap Chinese one at the same time as upgrading) and the only thing that I think is different is the max speed and velocity (The only one had to be quite low to avoid skipping steps).
    I did notice the same issue occurring on vertical moves in other files where it would start lifting just before it got to the end but I had assumed that was to do with the higher speeds it was running at which is evidently not the case now I have encountered this file.
    Code:
    (Generated with: DXF2GCODE, Version: PyQt4 Beta, Date: $Date: Tue Jun 9 17:40:00 2015 +0200 $)
    (Created from file: /home/cnc/Documents/CAD Drawings/Letters/N.dxf)
    (Time: Sun Aug 27 21:02:48 2017)
    G21 (Units in millimeters) G90 (Absolute programming) G64 (Default cutting) G17 (XY plane) G40 (Cancel radius comp.) G49 (Cancel length comp.)
    G0 Z  15.000
    (*** LAYER: Letters ***)
    T906 M6
    S14000
    (* SHAPE Nr: 0 *)
    G0 X  42.286 Y  19.286
    M3 M8
    G0 Z   3.000
    F100
    G1 Z  -1.200
    F1200
    G1 X  42.286 Y  65.689
    G1 X  63.714 Y  19.311
    G1 X  63.714 Y  65.714
    F100
    G1 Z  -2.400
    F1200
    G1 X  42.286 Y  19.286
    F100
    G1 Z   3.000
    G0 Z  15.000
    M9 M5
    G0 X   0.000 Y   0.000
    M2 (Program end)
    Attached Thumbnails Attached Thumbnails Curving between corners-untitled4-png
    Dec 2014
    Default Re: Curving between corners
    Turns out it's a combination issue of my new controller handling a higher max speed (but keeping the accel lower to avoid wobble in the gantry in sudden direction changes) and the result of a newer trajectory planning algorithm in 2.7 that was absent in 2.6.
    Member samco's Avatar
    Jul 2003
    Yes.. you need to specify a path following tolerance. G64Px.xxxx
