Newbie linuxcnc kinematics design
Results 1 to 5 of 5
Thread: linuxcnc kinematics design
    Mar 2005
    Default linuxcnc kinematics design
    Hi guys,
    i'm beginning with linuxcnc kinematics, and i was wondering what CAD was compatible/people use/recommend ?
    thank you
    Oct 2010
    Default Re: linuxcnc kinematics design
    I use QCAD. QCAD.org
    I'm sure others have their favorites...
    Mar 2005
    Quote Originally Posted by urbnsr View Post
    thanks for the reply,
    from my understanding this qcad works with 2d/3d axis, kinematic uses 3 axis + 3 joint (robot arm). it unclear to me how it works. could you clarify ?
    May 2015
    My understanding is that the Kinematics converts normal 3D moves to the motion required to move the robot arm to a given XYZ coordinate so its not so much of a problem. Granted additional joints allow angles to be selected. Some info here
    http://alvarestech.com/temp/RoboAsea...al-robot-2.pdf
    The Linuxcnc forum would be the place to ask for help on this topic.
    https://forum.linuxcnc.org/
    Rod Webster
    www.vmn.com.au
    Mar 2005
    Quote Originally Posted by rodw View Post
    So I could take a 3d cad and just plug and play as usual with cool thanks
