Guys,
I have made my own mini CNC
For testing I want to print this one :
In PC has a display :
Why is the x axis still out of the limit ? is it because of my setting ?
Code:
# Generated by stepconf at Wed Jun 27 18:18:25 2012
# If you make changes to this file, they will be
# overwritten when you run stepconf again
[EMC]
MACHINE = riko-mill
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /root/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = riko-mill.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.10
MAX_LINEAR_VELOCITY = 1.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = -0.1
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
STEPGEN_MAXACCEL = 37.5
SCALE = -8000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -0.11
MAX_LIMIT = 5.5
HOME_OFFSET = -0.1
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.0
SCALE = -8000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -0.4
MAX_LIMIT = 5.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = -1.1
MAX_VELOCITY = 1.0
SCALE = -8000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -2
MAX_LIMIT = 1.0
HOME_OFFSET = 2.0
G-code :
Code:
G20
G0 Z0.0120
G17 G40
G80 G90 G94
S1000 M3
G04 P3
G64 P0.0010
F12.0000
G18
F12.0000
G0 X-0.0534 Y1.6320
G2 X0.000000 Z0.000000 R0.125000
F12.0000
G1 X0.9540 Z-0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y1.5840
F12.0000
G1 X0.9540 Z-0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y1.5360
F12.0000
G1 X0.9540 Z-0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y1.4880
F12.0000
G1 X0.9540 Z-0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y1.4400
F12.0000
G1 X0.9540 Z-0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y1.3920
F12.0000
G1 X0.9540 Z-0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y1.3440
F12.0000
G1 X0.9540 Z-0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y1.2960
F12.0000
G1 X0.9540 Z-0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y1.2480
G2 X0.000000 Z-0.000000 R0.125000
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y1.2000
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y1.1520
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y1.1040
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y1.0560
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y1.0080
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.9600
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.9120
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.8640
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.8160
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.7680
F12.0000
G1 X0.9540 Z0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y0.7200
F12.0000
G1 X0.9540 Z0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y0.6720
F12.0000
G1 X0.9540 Z0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y0.6240
F12.0000
G1 X0.9540 Z0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y0.5760
F12.0000
G1 X0.9540 Z0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y0.5280
F12.0000
G1 X0.9540 Z0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y0.4800
F12.0000
G1 X0.9540 Z0.0000
F12.0000
G0 Z0.0120
X-0.0534 Y0.4320
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.3840
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.3360
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.2880
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.2400
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.1920
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.1440
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.0960
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.0480
F12.0000
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.0534 Y0.0060
F12.0000
G1 X0.9540
G0 Z0.0120
F12.0000
F12.0000
X-0.1243 Y1.6320
G2 X0.000000 Z-0.100000 R0.125000
F12.0000
G1 X0.1500
G2 X0.1620 Y1.6320 Z-0.0203 I-0.6816 K0.1433
G3 X0.1860 Y1.6320 Z-0.0090 I0.0240 K-0.0200
G3 X0.2100 Y1.6320 Z-0.0160 I-0.0020 K-0.0516
G1 X0.2160 Z-0.0140
X0.2280
G3 X0.2520 Y1.6320 Z-0.0273 I-0.0065 K-0.0400
G1 X0.2580 Z-0.0386
G2 X0.2700 Y1.6320 Z-0.1000 I0.2930 K0.0254
G1 X0.2940
X0.3000 Z-0.0425
X0.3060 Z-0.0224
G3 X0.3300 Y1.6320 Z-0.0108 I0.0240 K-0.0191
G3 X0.3480 Y1.6320 Z-0.0153 I-0.0012 K-0.0430
G1 X0.3660 Z-0.0155
X0.3780 Z-0.0179
G3 X0.3960 Y1.6320 Z-0.0333 I-0.0189 K-0.0404
G1 X0.4020 Z-0.0861
X0.4080 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y1.5840
F12.0000
G1 X0.0420
X0.0480 Z-0.0868
X0.0540 Z-0.0374
G3 X0.0720 Y1.5840 Z-0.0239 I0.0248 K-0.0144
G3 X0.1020 Y1.5840 Z-0.0177 I0.0315 K-0.0764
G3 X0.1200 Y1.5840 Z-0.0234 I-0.0003 K-0.0321
G3 X0.1440 Y1.5840 Z-0.0030 I0.0333 K-0.0149
G1 X0.1620
X0.1740 Z-0.0070
G3 X0.2040 Y1.5840 Z0.0000 I0.0379 K-0.0951
G3 X0.2280 Y1.5840 Z-0.0084 I-0.0010 K-0.0411
G3 X0.2460 Y1.5840 Z-0.0122 I-0.0028 K-0.0586
G3 X0.2640 Y1.5840 Z-0.0012 I0.0240 K-0.0191
G1 X0.2820 Z-0.0006
X0.2940 Z-0.0030
X0.3120 Z-0.0004
X0.3180 Z-0.0010
X0.3300 Z-0.0061
X0.3480 Z-0.0063
X0.3660 Z-0.0114
G3 X0.3780 Y1.5840 Z-0.0233 I-0.0167 K-0.0289
G1 X0.3900 Z-0.0285
X0.4020 Z-0.0259
X0.4140 Z-0.0283
G3 X0.4320 Y1.5840 Z-0.0214 I0.0190 K-0.0224
G1 X0.4560 Z-0.0259
G3 X0.4680 Y1.5840 Z-0.0362 I-0.0060 K-0.0191
G2 X0.4800 Y1.5840 Z-0.1000 I1.9367 K0.3314
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y1.5360
F12.0000
G1 X0.0240
G2 X0.0360 Y1.5360 Z-0.0152 I-0.3767 K0.0966
G3 X0.0480 Y1.5360 Z-0.0050 I0.0240 K-0.0160
G3 X0.0660 Y1.5360 Z0.0000 I0.0185 K-0.0318
G1 X0.0840 Z-0.0030
G3 X0.1020 Y1.5360 Z-0.0141 I-0.0072 K-0.0318
G1 X0.1140 Z-0.0153
X0.1260 Z-0.0143
G3 X0.1380 Y1.5360 Z-0.0076 I0.0180 K-0.0181
G1 X0.1500 Z-0.0057
X0.1620 Z-0.0087
X0.1800 Z-0.0086
X0.1920 Z-0.0139
G3 X0.2220 Y1.5360 Z-0.0043 I0.0347 K-0.0571
G1 X0.2340 Z-0.0067
X0.2520 Z-0.0145
X0.2700 Z-0.0071
X0.2880 Z-0.0053
X0.3000 Z-0.0077
X0.3120 Z-0.0055
X0.3360 Z-0.0072
G3 X0.3540 Y1.5360 Z-0.0174 I-0.0136 K-0.0449
G1 X0.3600 Z-0.0268
G3 X0.3720 Y1.5360 Z-0.0390 I-0.0245 K-0.0362
G1 X0.3780 Z-0.0417
X0.4020 Z-0.0763
G2 X0.4200 Y1.5360 Z-0.0445 I-0.2028 K0.1359
G3 X0.4500 Y1.5360 Z-0.0107 I0.3546 K-0.2842
G3 X0.4620 Y1.5360 Z-0.0050 I0.0180 K-0.0226
G2 X0.4800 Y1.5360 Z-0.0012 I-0.0032 K0.0597
G1 X0.4920
G3 X0.5160 Y1.5360 Z-0.0249 I-0.0060 K-0.0301
G1 X0.5220 Z-0.0845
X0.5280 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.0897 Y1.4880
G2 X0.000000 Z-0.025954 R0.125000
F12.0000
G3 X0.0300 Y1.4880 Z-0.0153 I0.0872 K-0.1979
G1 X0.0420
X0.0540 Z-0.0205
X0.0660 Z-0.0310
X0.0720 Z-0.0332
G3 X0.0960 Y1.4880 Z-0.0057 I0.0949 K-0.0585
G3 X0.1140 Y1.4880 Z0.0000 I0.0180 K-0.0255
G1 X0.1260 Z-0.0024
X0.1440 Z-0.0125
X0.1560
X0.1620 Z-0.0156
X0.1740 Z-0.0178
G3 X0.1860 Y1.4880 Z-0.0245 I-0.0060 K-0.0248
G1 X0.1920 Z-0.0259
G3 X0.2160 Y1.4880 Z-0.0076 I0.0321 K-0.0173
G1 X0.2280
X0.2400 Z-0.0128
X0.2460 Z-0.0131
G3 X0.2580 Y1.4880 Z-0.0064 I0.0180 K-0.0181
G1 X0.2760 Z-0.0033
X0.2880
G3 X0.3180 Y1.4880 Z-0.0249 I-0.0109 K-0.0468
G3 X0.3360 Y1.4880 Z-0.0149 I0.0335 K-0.0391
G3 X0.3480 Y1.4880 Z-0.0058 I0.0240 K-0.0191
G1 X0.3600 Z-0.0033
G3 X0.3780 Y1.4880 Z-0.0092 I-0.0000 K-0.0307
G3 X0.3900 Y1.4880 Z-0.0234 I-0.0303 K-0.0377
G2 X0.4020 Y1.4880 Z-0.0278 I0.0122 K0.0145
G3 X0.4260 Y1.4880 Z-0.0149 I0.0371 K-0.0400
G1 X0.4560 Z-0.0164
X0.4680 Z-0.0132
G3 X0.4800 Y1.4880 Z-0.0172 I-0.0000 K-0.0200
G1 X0.4860 Z-0.0245
X0.4980 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.0828 Y1.4400
G2 X0.000000 Z-0.019361 R0.125000
F12.0000
G1 X0.0120
X0.0300 Z-0.0286
X0.0360 Z-0.0358
X0.0420 Z-0.0590
G3 X0.0540 Y1.4400 Z-0.0238 I0.0610 K-0.0012
G3 X0.0780 Y1.4400 Z-0.0076 I0.0349 K-0.0259
G1 X0.0900
X0.0960 Z-0.0095
G3 X0.1080 Y1.4400 Z-0.0183 I-0.0120 K-0.0289
G3 X0.1200 Y1.4400 Z-0.0484 I-0.0761 K-0.0478
G1 X0.1260 Z-0.0592
G2 X0.1380 Y1.4400 Z-0.0401 I-0.0120 K0.0209
G3 X0.1500 Y1.4400 Z-0.0298 I0.0180 K-0.0087
G1 X0.1740 Z-0.0261
X0.1860 Z-0.0291
G3 X0.1980 Y1.4400 Z-0.0429 I-0.0120 K-0.0226
G2 X0.2100 Y1.4400 Z-0.1000 I0.2730 K0.0276
G1 X0.2640
X0.2700 Z-0.0849
G3 X0.2820 Y1.4400 Z-0.0303 I0.3042 K-0.0384
G1 X0.2880 Z-0.0231
X0.3060 Z-0.0117
X0.3180 Z-0.0091
G3 X0.3420 Y1.4400 Z-0.0186 I-0.0009 K-0.0373
G1 X0.3540 Z-0.0309
G3 X0.3780 Y1.4400 Z-0.0157 I0.0383 K-0.0338
G1 X0.3900
G3 X0.4080 Y1.4400 Z-0.0237 I-0.0138 K-0.0554
G3 X0.4200 Y1.4400 Z-0.0421 I-0.0180 K-0.0248
G1 X0.4260 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.0862 Y1.3920
G2 X0.000000 Z-0.022500 R0.125000
F12.0000
G3 X0.0120 Y1.3920 Z-0.0087 I0.0240 K-0.0088
G3 X0.0360 Y1.3920 Z-0.0022 I0.0266 K-0.0501
G1 X0.0480 Z-0.0046
G3 X0.0660 Y1.3920 Z-0.0185 I-0.0245 K-0.0503
G1 X0.1080 Z-0.0195
X0.1200 Z-0.0246
X0.1320 Z-0.0217
X0.1500 Z-0.0207
X0.1680 Z-0.0165
X0.1800
X0.1920 Z-0.0141
X0.2040 Z-0.0165
X0.2220 Z-0.0169
X0.2340 Z-0.0219
X0.2400 Z-0.0227
G3 X0.2580 Y1.3920 Z-0.0181 I0.0196 K-0.0394
G3 X0.2760 Y1.3920 Z-0.0220 I-0.0029 K-0.0560
G1 X0.2820 Z-0.0198
X0.3000 Z-0.0191
G3 X0.3120 Y1.3920 Z-0.0231 I-0.0000 K-0.0200
G3 X0.3360 Y1.3920 Z-0.0129 I0.0248 K-0.0254
G3 X0.3660 Y1.3920 Z-0.0305 I-0.0004 K-0.0350
G1 X0.3720 Z-0.0582
X0.3780 Z-0.0262
G3 X0.3900 Y1.3920 Z-0.0160 I0.0240 K-0.0160
G1 X0.3960 Z-0.0140
X0.4080 Z-0.0131
G3 X0.4260 Y1.3920 Z-0.0177 I-0.0011 K-0.0420
G3 X0.4380 Y1.3920 Z-0.0315 I-0.0120 K-0.0226
G1 X0.4440 Z-0.0915
X0.4500 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y1.3440
F12.0000
G1 X0.0360
G3 X0.0480 Y1.3440 Z-0.0347 I0.4587 K-0.0505
G1 X0.0720 Z-0.0277
X0.0960 Z-0.0336
X0.1020 Z-0.0333
G3 X0.1140 Y1.3440 Z-0.0293 I0.0120 K-0.0160
G1 X0.1260 Z-0.0294
G3 X0.1380 Y1.3440 Z-0.0376 I-0.0114 K-0.0296
G1 X0.1500 Z-0.0406
X0.1560 Z-0.0539
G2 X0.1680 Y1.3440 Z-0.1000 I0.2701 K0.0457
G1 X0.3120
X0.3180 Z-0.0872
X0.3240 Z-0.0278
X0.3300 Z-0.0212
G3 X0.3540 Y1.3440 Z-0.0127 I0.0263 K-0.0360
G3 X0.3720 Y1.3440 Z-0.0186 I-0.0000 K-0.0307
G3 X0.3840 Y1.3440 Z-0.0370 I-0.0180 K-0.0248
G1 X0.3900 Z-0.0766
X0.3960 Z-0.0262
G3 X0.4260 Y1.3440 Z-0.0102 I0.0315 K-0.0229
G3 X0.4560 Y1.3440 Z-0.0327 I0.0000 K-0.0312
G1 X0.4620 Z-0.0825
X0.4680 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y1.2960
F12.0000
G1 X0.3300
X0.3360 Z-0.0398
G3 X0.3480 Y1.2960 Z-0.0198 I0.0277 K-0.0031
G1 X0.3600 Z-0.0147
X0.3720
G3 X0.3900 Y1.2960 Z-0.0254 I-0.0060 K-0.0307
G1 X0.3960 Z-0.0366
X0.4020 Z-0.0802
X0.4080 Z-0.0684
X0.4140 Z-0.0274
G3 X0.4260 Y1.2960 Z-0.0172 I0.0240 K-0.0160
G1 X0.4440 Z-0.0139
G3 X0.4740 Y1.2960 Z-0.0382 I-0.0000 K-0.0307
G1 X0.4800 Z-0.0994
X0.9540 Z-0.1000
F12.0000
G0 Z0.0120
X-0.1243 Y1.2480
F12.0000
G1 X0.3420
G3 X0.3540 Y1.2480 Z-0.0285 I0.2556 K-0.0061
G3 X0.3780 Y1.2480 Z-0.0173 I0.0240 K-0.0200
G3 X0.4080 Y1.2480 Z-0.0398 I0.0000 K-0.0312
G2 X0.4200 Y1.2480 Z-0.1000 I0.2691 K0.0223
G1 X0.4260 Z-0.0464
X0.4320 Z-0.0275
G3 X0.4560 Y1.2480 Z-0.0159 I0.0240 K-0.0191
G3 X0.4860 Y1.2480 Z-0.0321 I-0.0006 K-0.0370
G3 X0.4980 Y1.2480 Z-0.1000 I-0.2469 K-0.0786
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y1.2000
F12.0000
G1 X0.3540
X0.3600 Z-0.0460
X0.3660 Z-0.0269
G3 X0.3900 Y1.2000 Z-0.0157 I0.0240 K-0.0200
G3 X0.4200 Y1.2000 Z-0.0382 I0.0000 K-0.0312
G1 X0.4260 Z-0.0970
X0.4320 Z-0.1000
G2 X0.4440 Y1.2000 Z-0.0313 I-0.6141 K0.1427
G3 X0.4680 Y1.2000 Z-0.0185 I0.0240 K-0.0160
G1 X0.4860 Z-0.0215
G3 X0.4980 Y1.2000 Z-0.0306 I-0.0120 K-0.0282
G1 X0.5040 Z-0.0433
X0.5100 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y1.1520
F12.0000
G1 X0.3600
X0.3660 Z-0.0978
X0.3720 Z-0.0325
G3 X0.3960 Y1.1520 Z-0.0197 I0.0240 K-0.0160
G1 X0.4080 Z-0.0203
X0.4140 Z-0.0223
G3 X0.4260 Y1.1520 Z-0.0325 I-0.0120 K-0.0262
G1 X0.4320 Z-0.0504
X0.4380 Z-0.1000
X0.4440
G2 X0.4560 Y1.1520 Z-0.0309 I-0.2169 K0.0733
G3 X0.4800 Y1.1520 Z-0.0181 I0.0240 K-0.0160
G1 X0.4980 Z-0.0211
G3 X0.5100 Y1.1520 Z-0.0310 I-0.0133 K-0.0284
G1 X0.5160 Z-0.0437
X0.5220 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y1.1040
F12.0000
G1 X0.3720
G3 X0.3840 Y1.1040 Z-0.0278 I0.3048 K-0.0136
G3 X0.4080 Y1.1040 Z-0.0163 I0.0240 K-0.0191
G3 X0.4380 Y1.1040 Z-0.0405 I-0.0000 K-0.0307
G1 X0.4440 Z-0.1000
X0.4560
G2 X0.4680 Y1.1040 Z-0.0298 I-0.4470 K0.1125
G3 X0.4920 Y1.1040 Z-0.0181 I0.0244 K-0.0195
G3 X0.5220 Y1.1040 Z-0.0337 I-0.0010 K-0.0387
G1 X0.5280 Z-0.0512
X0.5340 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y1.0560
F12.0000
G1 X0.3780
G2 X0.3900 Y1.0560 Z-0.0273 I-1.4721 K0.2804
G3 X0.4140 Y1.0560 Z-0.0161 I0.0240 K-0.0200
G3 X0.4440 Y1.0560 Z-0.0386 I0.0000 K-0.0312
G1 X0.4500 Z-0.1000
X0.4680
G3 X0.4800 Y1.0560 Z-0.0286 I0.6680 K-0.0756
G3 X0.5040 Y1.0560 Z-0.0171 I0.0240 K-0.0191
G3 X0.5340 Y1.0560 Z-0.0401 I-0.0000 K-0.0311
G3 X0.5460 Y1.0560 Z-0.1000 I-1.1193 K-0.2555
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y1.0080
F12.0000
G1 X0.3840
X0.3900 Z-0.0502
G3 X0.4200 Y1.0080 Z-0.0304 I0.0312 K-0.0147
G3 X0.4440 Y1.0080 Z-0.0420 I-0.0000 K-0.0307
G1 X0.4500 Z-0.0547
X0.4560 Z-0.1000
X0.4800
X0.4860 Z-0.0417
G3 X0.4980 Y1.0080 Z-0.0221 I0.0292 K-0.0044
G3 X0.5160 Y1.0080 Z-0.0163 I0.0180 K-0.0248
G3 X0.5400 Y1.0080 Z-0.0278 I-0.0000 K-0.0307
G1 X0.5460 Z-0.0406
X0.5520 Z-0.0939
X0.5580 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.9600
F12.0000
G1 X0.3840
G2 X0.3960 Y0.9600 Z-0.0297 I-0.5118 K0.1235
G3 X0.4200 Y0.9600 Z-0.0182 I0.0241 K-0.0196
G3 X0.4500 Y0.9600 Z-0.0409 I-0.0001 K-0.0312
G1 X0.4560 Z-0.1000
X0.4860
X0.4920 Z-0.0860
X0.4980 Z-0.0301
G3 X0.5220 Y0.9600 Z-0.0173 I0.0240 K-0.0160
G3 X0.5520 Y0.9600 Z-0.0360 I-0.0006 K-0.0343
G3 X0.5640 Y0.9600 Z-0.1000 I-0.1858 K-0.0680
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.9120
F12.0000
G1 X0.3840
G2 X0.3960 Y0.9120 Z-0.0301 I-0.5308 K0.1271
G3 X0.4200 Y0.9120 Z-0.0188 I0.0240 K-0.0200
G3 X0.4500 Y0.9120 Z-0.0413 I0.0000 K-0.0312
G1 X0.4560 Z-0.1000
X0.4980
X0.5040 Z-0.0468
X0.5100 Z-0.0271
G3 X0.5340 Y0.9120 Z-0.0155 I0.0240 K-0.0191
G3 X0.5580 Y0.9120 Z-0.0271 I-0.0000 K-0.0307
G1 X0.5640 Z-0.0398
X0.5700 Z-0.0966
X0.5760 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.8640
F12.0000
G1 X0.3840
X0.3900 Z-0.0557
X0.3960 Z-0.0408
G3 X0.4200 Y0.8640 Z-0.0292 I0.0240 K-0.0191
G3 X0.4500 Y0.8640 Z-0.0523 I-0.0000 K-0.0311
G1 X0.4560 Z-0.1000
X0.5040
X0.5100 Z-0.0837
X0.5160 Z-0.0286
G3 X0.5400 Y0.8640 Z-0.0171 I0.0240 K-0.0191
G3 X0.5640 Y0.8640 Z-0.0286 I-0.0000 K-0.0307
G1 X0.5700 Z-0.0414
G3 X0.5820 Y0.8640 Z-0.1000 I-0.5017 K-0.1332
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.8160
F12.0000
G1 X0.3780
X0.3840 Z-0.0988
X0.3900 Z-0.0369
G3 X0.4140 Y0.8160 Z-0.0251 I0.0244 K-0.0195
G3 X0.4380 Y0.8160 Z-0.0369 I-0.0002 K-0.0309
G1 X0.4440 Z-0.0496
X0.4560 Z-0.1000
X0.5160
X0.5220 Z-0.0394
G3 X0.5520 Y0.8160 Z-0.0185 I0.0319 K-0.0138
G3 X0.5760 Y0.8160 Z-0.0313 I-0.0000 K-0.0289
G1 X0.5820 Z-0.0457
X0.5880 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.7680
F12.0000
G1 X0.3780
X0.3840 Z-0.0871
X0.3900 Z-0.0273
G3 X0.4140 Y0.7680 Z-0.0159 I0.0241 K-0.0196
G3 X0.4440 Y0.7680 Z-0.0386 I-0.0001 K-0.0312
G1 X0.4500 Z-0.1000
X0.5220
G3 X0.5340 Y0.7680 Z-0.0277 I0.6134 K-0.0647
G3 X0.5580 Y0.7680 Z-0.0165 I0.0240 K-0.0200
G3 X0.5880 Y0.7680 Z-0.0390 I0.0000 K-0.0312
G1 X0.5940 Z-0.0994
X0.9540 Z-0.1000
F12.0000
G0 Z0.0120
X-0.1243 Y0.7200
F12.0000
G1 X0.3780
G2 X0.3900 Y0.7200 Z-0.0324 I-0.3335 K0.0941
G3 X0.4140 Y0.7200 Z-0.0212 I0.0240 K-0.0200
G3 X0.4440 Y0.7200 Z-0.0437 I0.0000 K-0.0312
G1 X0.4500 Z-0.1000
X0.5280
X0.5340 Z-0.0782
X0.5400 Z-0.0242
G3 X0.5640 Y0.7200 Z-0.0129 I0.0240 K-0.0200
G3 X0.5880 Y0.7200 Z-0.0205 I-0.0010 K-0.0447
G1 X0.6000 Z-0.0207
X0.6060 Z-0.0227
X0.6240 Z-0.0225
G3 X0.6480 Y0.7200 Z-0.0321 I-0.0205 K-0.0860
G1 X0.6540 Z-0.0394
G2 X0.6660 Y0.7200 Z-0.1000 I1.3142 K0.2286
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.6720
F12.0000
G1 X0.3780
G2 X0.3900 Y0.6720 Z-0.0324 I-0.4992 K0.1235
G3 X0.4140 Y0.6720 Z-0.0212 I0.0240 K-0.0200
G3 X0.4440 Y0.6720 Z-0.0437 I0.0000 K-0.0312
G1 X0.4500 Z-0.1000
X0.5820
X0.5880 Z-0.0939
X0.6060 Z-0.0437
X0.6180 Z-0.0294
G3 X0.6300 Y0.6720 Z-0.0252 I0.0130 K-0.0179
G1 X0.6540 Z-0.0077
X0.6840 Z-0.0018
G3 X0.7080 Y0.6720 Z-0.0126 I-0.0002 K-0.0323
G1 X0.7140 Z-0.0192
G2 X0.7260 Y0.6720 Z-0.0421 I0.0596 K0.0165
G1 X0.7320 Z-0.1000
X0.8340
X0.8400 Z-0.0547
G3 X0.8580 Y0.6720 Z-0.0152 I0.0785 K-0.0120
G1 X0.8640 Z-0.0122
X0.8760
G3 X0.8880 Y0.6720 Z-0.0225 I-0.0060 K-0.0191
G1 X0.8940 Z-0.0343
X0.9000 Z-0.0884
G3 X0.9120 Y0.6720 Z-0.0280 I0.2046 K-0.0093
G3 X0.9300 Y0.6720 Z-0.0103 I0.0524 K-0.0353
G1 X0.9420 Z-0.0073
X0.9540 Z-0.0103
F12.0000
G0 Z0.0120
X-0.1243 Y0.6240
F12.0000
G1 X0.3780
X0.3840 Z-0.0913
X0.3900 Z-0.0309
G3 X0.4140 Y0.6240 Z-0.0181 I0.0240 K-0.0160
G3 X0.4380 Y0.6240 Z-0.0309 I-0.0000 K-0.0289
G1 X0.4440 Z-0.0433
G2 X0.4560 Y0.6240 Z-0.1000 I0.1485 K0.0018
G1 X0.6780
X0.6840 Z-0.0390
G3 X0.6960 Y0.6240 Z-0.0286 I0.0180 K-0.0087
G2 X0.7260 Y0.6240 Z-0.0148 I-0.0424 K0.1315
G1 X0.7380 Z-0.0122
G3 X0.7560 Y0.6240 Z-0.0169 I-0.0014 K-0.0417
G3 X0.7680 Y0.6240 Z-0.0307 I-0.0120 K-0.0226
G1 X0.7740 Z-0.0872
X0.7800 Z-0.1000
X0.8340
X0.8400 Z-0.0815
X0.8460 Z-0.0225
G3 X0.8580 Y0.6240 Z-0.0087 I0.0240 K-0.0088
G1 X0.8880 Z-0.0024
G3 X0.9060 Y0.6240 Z-0.0087 I-0.0000 K-0.0289
G1 X0.9120 Z-0.0095
X0.9240 Z-0.0065
X0.9360 Z-0.0092
X0.9480 Z-0.0099
X0.9540 Z-0.0122
F12.0000
G0 Z0.0120
X-0.1243 Y0.5760
F12.0000
G1 X0.3840
X0.3900 Z-0.0801
X0.3960 Z-0.0290
G3 X0.4200 Y0.5760 Z-0.0174 I0.0240 K-0.0191
G3 X0.4380 Y0.5760 Z-0.0215 I-0.0020 K-0.0512
G3 X0.4500 Y0.5760 Z-0.0317 I-0.0120 K-0.0262
G3 X0.4620 Y0.5760 Z-0.1000 I-0.3080 K-0.0893
G1 X0.7200
G3 X0.7320 Y0.5760 Z-0.0274 I0.3180 K-0.0153
G3 X0.7440 Y0.5760 Z-0.0172 I0.0240 K-0.0160
G1 X0.7680 Z-0.0120
G3 X0.7980 Y0.5760 Z-0.0363 I-0.0000 K-0.0307
G1 X0.8040 Z-0.1000
X0.8280
X0.8340 Z-0.0900
X0.8400 Z-0.0386
X0.8460 Z-0.0195
G3 X0.8580 Y0.5760 Z-0.0093 I0.0240 K-0.0160
G3 X0.8760 Y0.5760 Z-0.0040 I0.0187 K-0.0298
G1 X0.8880 Z-0.0066
X0.9000 Z-0.0049
X0.9120 Z-0.0053
G3 X0.9360 Y0.5760 Z-0.0201 I-0.0095 K-0.0423
G3 X0.9480 Y0.5760 Z-0.0243 I-0.0010 K-0.0221
G1 X0.9540 Z-0.0308
F12.0000
G0 Z0.0120
X-0.1243 Y0.5280
F12.0000
G1 X0.3960
G2 X0.4080 Y0.5280 Z-0.0294 I-0.2641 K0.0812
G1 X0.4140 Z-0.0122
G3 X0.4380 Y0.5280 Z-0.0006 I0.0240 K-0.0191
G3 X0.4620 Y0.5280 Z-0.0122 I-0.0000 K-0.0307
G2 X0.4740 Y0.5280 Z-0.0358 I0.2012 K0.0871
G1 X0.4800 Z-0.1000
X0.4920
G3 X0.5040 Y0.5280 Z-0.0723 I0.2068 K-0.0732
G3 X0.5220 Y0.5280 Z-0.0610 I0.0180 K-0.0088
G3 X0.5400 Y0.5280 Z-0.0723 I-0.0000 K-0.0200
G1 X0.5460 Z-0.1000
X0.7440
X0.7500 Z-0.0450
X0.7560 Z-0.0267
X0.7620 Z-0.0209
G3 X0.7800 Y0.5280 Z-0.0132 I0.0191 K-0.0198
G3 X0.7920 Y0.5280 Z-0.0172 I-0.0000 K-0.0200
G1 X0.8280 Z-0.0184
X0.8340 Z-0.0169
X0.8460 Z-0.0085
X0.8580 Z-0.0061
G3 X0.8880 Y0.5280 Z-0.0231 I-0.0005 K-0.0359
G1 X0.8940 Z-0.0421
X0.9000 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.4800
F12.0000
G1 X0.3960
X0.4020 Z-0.0906
X0.4080 Z-0.0314
G3 X0.4320 Y0.4800 Z-0.0198 I0.0240 K-0.0191
G3 X0.4500 Y0.4800 Z-0.0050 I0.0387 K-0.0288
G1 X0.4620 Z-0.0024
X0.4920 Z-0.0046
G3 X0.5100 Y0.4800 Z-0.0168 I-0.0060 K-0.0282
G1 X0.5220 Z-0.0180
X0.5280 Z-0.0211
G3 X0.5460 Y0.4800 Z-0.0464 I-0.1132 K-0.0996
G3 X0.5580 Y0.4800 Z-0.1000 I-0.1992 K-0.0728
G1 X0.5820
X0.5880 Z-0.0395
G3 X0.6120 Y0.4800 Z-0.0241 I0.0243 K-0.0115
G1 X0.6240 Z-0.0271
G3 X0.6420 Y0.4800 Z-0.0396 I-0.0153 K-0.0413
G1 X0.6480 Z-0.0523
X0.6540 Z-0.1000
X0.6600
G3 X0.6720 Y0.4800 Z-0.0358 I0.1781 K-0.0001
G3 X0.6900 Y0.4800 Z-0.0246 I0.0180 K-0.0087
G3 X0.7080 Y0.4800 Z-0.0358 I0.0000 K-0.0200
G3 X0.7200 Y0.4800 Z-0.0931 I-0.1698 K-0.0655
G1 X0.7260 Z-0.1000
X0.7440
G2 X0.7560 Y0.4800 Z-0.0332 I-0.5619 K0.1354
G1 X0.7680 Z-0.0172
G3 X0.7800 Y0.4800 Z-0.0132 I0.0120 K-0.0160
G3 X0.7920 Y0.4800 Z-0.0172 I-0.0000 K-0.0200
G3 X0.8100 Y0.4800 Z-0.0445 I-0.0789 K-0.0716
G2 X0.8220 Y0.4800 Z-0.1000 I0.2503 K0.0250
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.4320
F12.0000
G1 X0.3960
X0.4020 Z-0.0873
X0.4080 Z-0.0277
G3 X0.4320 Y0.4320 Z-0.0165 I0.0240 K-0.0200
G3 X0.4620 Y0.4320 Z-0.0390 I0.0000 K-0.0312
G1 X0.4680 Z-0.0962
X0.4740 Z-0.1000
X0.4860 Z-0.0394
X0.4920 Z-0.0207
G3 X0.5160 Y0.4320 Z-0.0061 I0.0246 K-0.0134
G3 X0.5400 Y0.4320 Z-0.0207 I-0.0002 K-0.0274
G1 X0.5460 Z-0.0370
X0.5520 Z-0.0864
X0.5580 Z-0.1000
X0.5760
X0.5820 Z-0.0356
G3 X0.5940 Y0.4320 Z-0.0135 I0.0285 K-0.0011
G3 X0.6120 Y0.4320 Z-0.0076 I0.0180 K-0.0248
G1 X0.6240 Z-0.0100
X0.6360
X0.6540 Z-0.0167
X0.6720 Z-0.0034
X0.6840 Z-0.0010
G3 X0.7140 Y0.4320 Z-0.0253 I-0.0000 K-0.0307
G3 X0.7260 Y0.4320 Z-0.1000 I-4.8326 K-0.8144
G1 X0.7440
X0.7500 Z-0.0372
G3 X0.7740 Y0.4320 Z-0.0234 I0.0250 K-0.0156
G3 X0.7980 Y0.4320 Z-0.0372 I-0.0003 K-0.0283
G3 X0.8160 Y0.4320 Z-0.1000 I-0.1019 K-0.0632
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.3840
F12.0000
G1 X0.3960
X0.4020 Z-0.0976
X0.4080 Z-0.0376
X0.4140 Z-0.0319
G3 X0.4320 Y0.3840 Z-0.0261 I0.0180 K-0.0248
G3 X0.4500 Y0.3840 Z-0.0319 I-0.0000 K-0.0307
G1 X0.4560 Z-0.0376
G3 X0.4680 Y0.3840 Z-0.0672 I-0.1412 K-0.0745
G1 X0.4740 Z-0.0401
X0.4800 Z-0.0308
X0.4980 Z-0.0091
G3 X0.5160 Y0.3840 Z-0.0028 I0.0180 K-0.0226
G3 X0.5400 Y0.3840 Z-0.0156 I-0.0000 K-0.0289
G3 X0.5520 Y0.3840 Z-0.0880 I-0.2158 K-0.0730
G1 X0.5580 Z-0.1000
X0.5640
X0.5700 Z-0.0433
X0.5760 Z-0.0269
G3 X0.6000 Y0.3840 Z-0.0157 I0.0240 K-0.0200
G1 X0.6120 Z-0.0181
X0.6300 Z-0.0314
X0.6420 Z-0.0366
G3 X0.6540 Y0.3840 Z-0.0533 I-0.0204 K-0.0274
G1 X0.6600 Z-0.0289
X0.6660 Z-0.0234
G3 X0.6840 Y0.3840 Z-0.0176 I0.0180 K-0.0255
G3 X0.7020 Y0.3840 Z-0.0234 I0.0000 K-0.0312
G3 X0.7140 Y0.3840 Z-0.0401 I-0.0180 K-0.0255
G1 X0.7200 Z-0.0947
X0.7260 Z-0.1000
X0.7320
G3 X0.7440 Y0.3840 Z-0.0286 I0.3988 K-0.0304
G3 X0.7680 Y0.3840 Z-0.0171 I0.0240 K-0.0191
G3 X0.7920 Y0.3840 Z-0.0286 I-0.0000 K-0.0307
G1 X0.7980 Z-0.0405
G2 X0.8100 Y0.3840 Z-0.1000 I0.4314 K0.0561
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.3360
F12.0000
G1 X0.4020
X0.4080 Z-0.0799
X0.4140 Z-0.0294
G3 X0.4260 Y0.3360 Z-0.0203 I0.0240 K-0.0191
G1 X0.4320 Z-0.0184
X0.4440
X0.4560 Z-0.0237
X0.4620 Z-0.0225
G3 X0.4740 Y0.3360 Z-0.0140 I0.0278 K-0.0264
G1 X0.4800 Z-0.0122
X0.4920
G3 X0.5160 Y0.3360 Z-0.0282 I-0.0088 K-0.0390
G1 X0.5280 Z-0.0285
G3 X0.5400 Y0.3360 Z-0.0342 I-0.0060 K-0.0282
G3 X0.5520 Y0.3360 Z-0.0543 I-0.0237 K-0.0278
G1 X0.5580 Z-0.0262
G3 X0.5700 Y0.3360 Z-0.0160 I0.0240 K-0.0160
G1 X0.5820 Z-0.0134
X0.5940 Z-0.0137
G3 X0.6120 Y0.3360 Z-0.0221 I-0.0118 K-0.0488
G1 X0.6240 Z-0.0169
X0.6360
G3 X0.6540 Y0.3360 Z-0.0278 I-0.0060 K-0.0301
G3 X0.6840 Y0.3360 Z-0.0047 I0.0314 K-0.0098
G3 X0.7080 Y0.3360 Z-0.0176 I-0.0000 K-0.0289
G3 X0.7200 Y0.3360 Z-0.0790 I-0.2985 K-0.0902
G1 X0.7260 Z-0.0358
X0.7320 Z-0.0246
G3 X0.7560 Y0.3360 Z-0.0133 I0.0240 K-0.0200
G3 X0.7860 Y0.3360 Z-0.0358 I0.0000 K-0.0312
G2 X0.7980 Y0.3360 Z-0.1000 I0.3846 K0.0387
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.2880
F12.0000
G1 X0.4020
X0.4080 Z-0.0438
X0.4140 Z-0.0243
G3 X0.4260 Y0.2880 Z-0.0140 I0.0240 K-0.0160
G1 X0.4380 Z-0.0114
X0.4440 Z-0.0120
X0.4620 Z-0.0191
X0.4680 Z-0.0171
X0.4800
G3 X0.4980 Y0.2880 Z-0.0269 I-0.0097 K-0.0395
G1 X0.5040 Z-0.0263
G3 X0.5160 Y0.2880 Z-0.0207 I0.0180 K-0.0226
G1 X0.5280
X0.5340 Z-0.0227
X0.5400 Z-0.0216
G3 X0.5520 Y0.2880 Z-0.0124 I0.0240 K-0.0191
G1 X0.5700 Z-0.0092
G3 X0.6000 Y0.2880 Z-0.0335 I-0.0000 K-0.0307
G1 X0.6060 Z-0.0333
G3 X0.6300 Y0.2880 Z-0.0161 I0.0341 K-0.0222
G1 X0.6420
X0.6540 Z-0.0213
G2 X0.6780 Y0.2880 Z-0.0122 I-0.0120 K0.0675
G1 X0.6840 Z-0.0112
G3 X0.6960 Y0.2880 Z-0.0152 I-0.0000 K-0.0200
G1 X0.7080 Z-0.0237
X0.7140 Z-0.0235
G3 X0.7320 Y0.2880 Z-0.0125 I0.0240 K-0.0191
G1 X0.7440
X0.7560 Z-0.0168
G3 X0.7740 Y0.2880 Z-0.0386 I-0.0120 K-0.0282
G1 X0.7800 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.2400
F12.0000
G1 X0.4020
X0.4080 Z-0.0511
X0.4140 Z-0.0265
X0.4200 Z-0.0210
X0.4320 Z-0.0159
X0.4440
X0.4560 Z-0.0210
X0.4680 Z-0.0208
X0.4800 Z-0.0234
G3 X0.4920 Y0.2400 Z-0.0325 I-0.0120 K-0.0282
G3 X0.5220 Y0.2400 Z-0.0122 I0.0306 K-0.0128
G1 X0.5280 Z-0.0127
X0.5460 Z-0.0191
X0.5580 Z-0.0167
X0.5700 Z-0.0191
G3 X0.5880 Y0.2400 Z-0.0337 I-0.0209 K-0.0443
G1 X0.5940 Z-0.0472
X0.6000 Z-0.1000
G2 X0.6120 Y0.2400 Z-0.0298 I-0.2763 K0.0834
G1 X0.6180 Z-0.0241
X0.6300 Z-0.0187
X0.6360 Z-0.0181
X0.6540 Z-0.0207
X0.6600 Z-0.0187
X0.6720
G3 X0.6900 Y0.2400 Z-0.0135 I0.0185 K-0.0303
G3 X0.7080 Y0.2400 Z-0.0194 I0.0000 K-0.0307
G3 X0.7320 Y0.2400 Z-0.0112 I0.0283 K-0.0438
G3 X0.7560 Y0.2400 Z-0.0227 I-0.0000 K-0.0307
G3 X0.7680 Y0.2400 Z-0.0515 I-0.1662 K-0.0861
G1 X0.7740 Z-0.1000
X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.1920
F12.0000
G1 X0.3900
G3 X0.4020 Y0.1920 Z-0.0267 I0.3404 K-0.0181
G3 X0.4260 Y0.1920 Z-0.0151 I0.0240 K-0.0191
G3 X0.4440 Y0.1920 Z-0.0199 I-0.0009 K-0.0394
G1 X0.4560 Z-0.0174
X0.4680 Z-0.0199
G3 X0.4860 Y0.1920 Z-0.0405 I-0.0125 K-0.0290
G3 X0.5100 Y0.1920 Z-0.0203 I0.0335 K-0.0153
G1 X0.5280 Z-0.0195
X0.5460 Z-0.0163
X0.5580 Z-0.0187
G3 X0.5760 Y0.1920 Z-0.0406 I-0.0120 K-0.0282
G3 X0.5880 Y0.1920 Z-0.1000 I-1.5271 K-0.3393
G2 X0.6000 Y0.1920 Z-0.0294 I-2.7805 K0.5086
G3 X0.6180 Y0.1920 Z-0.0171 I0.0240 K-0.0160
G1 X0.6240 Z-0.0165
X0.6420 Z-0.0187
X0.6540 Z-0.0163
G3 X0.6720 Y0.1920 Z-0.0221 I-0.0000 K-0.0307
G1 X0.6780 Z-0.0227
X0.6900 Z-0.0200
X0.7020 Z-0.0227
G3 X0.7200 Y0.1920 Z-0.0171 I0.0186 K-0.0281
G3 X0.7380 Y0.1920 Z-0.0229 I-0.0000 K-0.0307
G3 X0.7500 Y0.1920 Z-0.0405 I-0.0189 K-0.0257
G2 X0.7620 Y0.1920 Z-0.1000 I1.7859 K0.3295
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.1440
F12.0000
G1 X0.3720
X0.3780 Z-0.0919
X0.3840 Z-0.0333
G3 X0.4140 Y0.1440 Z-0.0133 I0.0308 K-0.0138
G3 X0.4320 Y0.1440 Z-0.0175 I-0.0016 K-0.0473
G1 X0.4440 Z-0.0173
X0.4560 Z-0.0199
G3 X0.4740 Y0.1440 Z-0.0421 I-0.0134 K-0.0293
G3 X0.4920 Y0.1440 Z-0.0195 I0.0347 K-0.0092
G1 X0.4980 Z-0.0175
X0.5220 Z-0.0168
X0.5340 Z-0.0143
X0.5460 Z-0.0168
G3 X0.5640 Y0.1440 Z-0.0341 I-0.0151 K-0.0337
G2 X0.5760 Y0.1440 Z-0.0727 I0.0807 K0.0039
G1 X0.5820 Z-0.0262
G3 X0.5940 Y0.1440 Z-0.0160 I0.0240 K-0.0160
G1 X0.6060 Z-0.0134
X0.6240 Z-0.0165
X0.6420 Z-0.0137
G3 X0.6600 Y0.1440 Z-0.0194 I0.0000 K-0.0312
G3 X0.6780 Y0.1440 Z-0.0151 I0.0195 K-0.0413
G1 X0.6900 Z-0.0175
X0.7080 Z-0.0147
X0.7140 Z-0.0153
G3 X0.7380 Y0.1440 Z-0.0325 I-0.0080 K-0.0365
G3 X0.7500 Y0.1440 Z-0.1000 I-0.1926 K-0.0690
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.0960
F12.0000
G1 X0.3240
X0.3300 Z-0.0405
G3 X0.3420 Y0.0960 Z-0.0236 I0.0439 K-0.0184
G1 X0.3660 Z-0.0118
X0.3780 Z-0.0094
G3 X0.4020 Y0.0960 Z-0.0139 I-0.0036 K-0.0848
G1 X0.4080 Z-0.0131
X0.4200 Z-0.0078
X0.4320
G3 X0.4560 Y0.0960 Z-0.0315 I-0.0060 K-0.0301
G1 X0.4680 Z-0.0139
G3 X0.4800 Y0.0960 Z-0.0072 I0.0180 K-0.0181
G1 X0.4920
X0.5100 Z-0.0164
X0.5220 Z-0.0139
X0.5400 Z-0.0174
X0.5520 Z-0.0122
X0.5640
G3 X0.5880 Y0.0960 Z-0.0024 I0.0266 K-0.0310
G3 X0.6060 Y0.0960 Z-0.0087 I-0.0000 K-0.0289
G1 X0.6180 Z-0.0053
X0.6300
X0.6420 Z-0.0104
X0.6600 Z-0.0099
G3 X0.6840 Y0.0960 Z-0.0165 I-0.0075 K-0.0746
G1 X0.6900 Z-0.0147
X0.7020
X0.7140 Z-0.0198
G3 X0.7260 Y0.0960 Z-0.0366 I-0.0180 K-0.0255
G2 X0.7380 Y0.0960 Z-0.1000 I0.2456 K0.0137
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.0480
F12.0000
G1 X0.3120
X0.3180 Z-0.0266
G3 X0.3300 Y0.0480 Z-0.0164 I0.0240 K-0.0160
G1 X0.3420 Z-0.0138
G3 X0.3600 Y0.0480 Z-0.0179 I-0.0023 K-0.0512
G1 X0.3720 Z-0.0176
X0.3900 Z-0.0206
G3 X0.4140 Y0.0480 Z-0.0114 I0.0366 K-0.0592
G1 X0.4320 Z-0.0124
X0.4440 Z-0.0102
X0.4560 Z-0.0105
G3 X0.4740 Y0.0480 Z-0.0057 I0.0203 K-0.0403
G3 X0.4980 Y0.0480 Z-0.0191 I-0.0004 K-0.0289
G1 X0.5100 Z-0.0167
G3 X0.5280 Y0.0480 Z-0.0207 I-0.0021 K-0.0517
G1 X0.5460 Z-0.0183
X0.5580 Z-0.0192
X0.5700 Z-0.0178
X0.5820 Z-0.0203
G3 X0.6120 Y0.0480 Z-0.0006 I0.0313 K-0.0150
G3 X0.6300 Y0.0480 Z-0.0064 I-0.0000 K-0.0307
G1 X0.6480 Z-0.0068
G3 X0.6600 Y0.0480 Z-0.0135 I-0.0060 K-0.0248
G3 X0.6840 Y0.0480 Z-0.0040 I0.0269 K-0.0327
G3 X0.7020 Y0.0480 Z-0.0103 I-0.0000 K-0.0289
G3 X0.7140 Y0.0480 Z-0.0359 I-0.0213 K-0.0256
G2 X0.7260 Y0.0480 Z-0.1000 I0.5438 K0.0685
G1 X0.9540
F12.0000
G0 Z0.0120
X-0.1243 Y0.0060
F12.0000
G1 X0.3960
X0.4020 Z-0.0394
G3 X0.4140 Y0.0060 Z-0.0189 I0.0353 K-0.0069
G3 X0.4320 Y0.0060 Z-0.0126 I0.0180 K-0.0226
G1 X0.4440 Z-0.0152
X0.4620 Z-0.0157
X0.4740 Z-0.0190
X0.4860 Z-0.0137
X0.5040 Z-0.0122
G3 X0.5340 Y0.0060 Z-0.0335 I-0.0004 K-0.0323
G3 X0.5460 Y0.0060 Z-0.1000 I-0.3404 K-0.0957
G1 X0.5640
G3 X0.5760 Y0.0060 Z-0.0288 I1.4469 K-0.2072
G1 X0.5820 Z-0.0194
G3 X0.6000 Y0.0060 Z-0.0120 I0.0180 K-0.0181
G3 X0.6240 Y0.0060 Z-0.0187 I-0.0042 K-0.0610
G1 X0.6480 Z-0.0173
X0.6600 Z-0.0136
G3 X0.6720 Y0.0060 Z-0.0072 I0.0191 K-0.0213
G1 X0.6780 Z-0.0065
G3 X0.7020 Y0.0060 Z-0.0233 I0.0000 K-0.0255
G1 X0.7080 Z-0.0790
X0.7140 Z-0.1000
X0.9540
G0 Z0.0120
M2
Any ideas will be very appreciated ,
