A properly assembled axis that long should be easy to push along (by hand) with linear rails. I don't think the motors would have a problem if you can rotate the ballscrew freely by hand.
Another thought is with that ballscrew you could run with bearings at the motor end only, the other end cropped, reducing friction further.
